New member Username: Gangstagangsta
Post Number: 5 Registered: Feb-08
Posted on i need help what are the box dimensions and everything i need to build a truck box for three 10 inch kicker cvr's and i want the box to be ported |
Post Number: 6 Registered: Feb-08
Posted on or i just need a site or somthing so i can figure the dimensions out for the truck box |
Post Number: 8 Registered: Feb-08
Posted on its dual voice coil 4ohm |
Gold Member Username: Its_bacon12
Hfl,
Ny
Usa
Post Number: 1266 Registered: Dec-03
Posted on pick out the tightest dimesnions you can work with and try to get .75 cubic feet per sub after all displacements |
Post Number: 9 Registered: Feb-08
Posted on how would i do that its behind a truck seat im sorta new to all this |
