Can you use the same anthena to configure Pansat & Viewsat?? I had tried it with no results on viewsat, so i did something wrong or is not possible since i didnt get any channel. Maybe this is not the right words to askt this, how you understand.
You can use the same Antenna for all receivers. There may be differences in the software as to how to alert the particular receiver as to how you are connected.
