Hi there! I have a problem with my pansat converted to 2700. Some how my signal disapear. When I press on remote (SIG) it take me to the (SKEW) signal window on TV. There are two BAR, one for LEVEL and the other one for SIGNAL. Level is ok 90%, but signal is 0%. My all TP, all setting and connection is fine, because i am running same other receiver on it and that is working fine.On top of the BAR is written UNLOCK instead of LOCK. So How can i get signal in LOCK. If you can help me or anyone i will be appricate it. I am waiting for your sulotion please.
Note down your Antenna settings. Do factory default settings. Do TV setting. Switch off at the back - Switch on after 1 minute. Do Dish setup - One antenna setup only. Do Blind Scan (Power Scan) Do the other Sats.
