I downloaded this program called EmuNation 3.0.2.6. I really don't know how to use it. I opened it up and all I found some .dll and some other extension files. I assume it must be like a plugin. Can anyone please advise me how to use it? Thanks in advance.
It is used as a plugin for programs like mytheatre or progdvb ect. to use it you have to put the pthreadVC2.dll file in your main program file and then you put the rest of the files that are packed in the "plugins" folder into the plugins folder of your dvb program. as of now emunation 3.0.2.6 is down for DN and up for bev.
3.0.3.0 is out you put the files in there correct spot, it sometimes takes a little bit but emunation will automatically update the codes in the softcam.key file or you can go to your favorite website and get the keys i use www.dss-keys.co*m and punch them in, in there respective provider ID's.
