Im new at this stuff and wanted to see if I could get some help, I have Viewsat Xtreme- Dish Network box and I need keys how do I get them? Do I download or insert manually?
you have 4 lines of 16 and the keys are two lines of 32.so you type in the first 32 in your first 2 lines and last 32 in your last 2 lines, but it ain't gonna work because DN is down right now.wait for new bin and we can help you then
Listen to African. However, in the meantime, just because you have four lines..doesn't mean you input four lines. It's 86 & 96 that matter. On some receivers, 00 & 01 and CW is different also, but it's basically the same, just different numbers, but just two lines.
So in other words, you ignore all the others except for the two of significance.
Jose, you don't need new keys,we have had a ecm that means dn is down.we need new bins for this,just keep looking and when when new bins come out we will help you load them.in the mean time don't do anything to your receiver
Yes, you do in regard to the update/loader. In addition, you need to wait for the new bin, and they key issue will be resolved. However, it's always good to know how to manually insert the keys.
