2500 Conversions. Which BIN/Remote.
Username: Nydas
Post Number: 7904
There is a lot of confusion and wrong information being given. This is C/P from Fwank7 who modified the BINs and created the two jvvh_248 BINs.
C/P
From fwank7................
For peps that are confused on what bin you should choose and It's all in the
"REMOTE CONTROL" you have. The only one this really one this really affects and changes is for Pansat 2500 Remote users.
Yes your remote will still work but you need to use the Jvvh_FortecRemote bin thats all.
Pansat 2500 remote = Jvvh_FortecRemote bin
Fortec remote = Jvvh_FortecRemote bin
Pantec remote = Jvvh_FortecRemote bin
Pansat 2700 remote = Jvvh_PansatRemote bin,:
Sorry all but I still see peps getting confused Hope this clears it up.
Sorry do to new mods in BL bins this is the way it will be until told otherwise.
Username: Nydas
Post Number: 7905
So in the current crop of Version 248 Conversion, there is nothing like a good BIN and bad BIN. They are all good. Just make the right choice.
Most conversion STBS will work with the Fortec Remote BIN by any author, unless you have a Pansat 2700 remote. Only then do you need to select PansatRemote BIN by jvvh or anybody else.
Username: Gmanrus
Post Number: 108
Which one do I need to use if I have Pansat 2500a conv. to Pansat 2700????? Thank u for being patient...
Username: Nydas
Post Number: 7907
G-MANrus: I thought Fwank7 had made it very clear.
or CS_248T_lightning
Username: Gmanrus
Post Number: 109
Yeah, it's clear but it doesn't say that
for Pansat 2500a conv. to Pansat 2700 right? That's why I asked u. I installed jvvh_pansat248 and my remote controll doesn't work, but I have picture.
Username: Roundtree
Post Number: 29
what is the difference between Jvvh_FortecRemote bin or CS_248T_lightning bin
i have a pansat 2500 clone converted to pansat 2700.
Username: Psychmonster
Rhodium MemberAint nuthin ...
Post Number: 690
I addressed this 3 days.... they are all interchangable..JVVH and CS fortec and pansats bins all are basically the same although JVVH has been more dependable lately and may be modded better...
Username: Nydas
Post Number: 7909
IntTex and G-MANrus : I will repeat once more:
Most conversion STBS will work with the Fortec Remote BIN.
Same applies to using CS_248T_lightning. It is essentially a FortecRemote BIN
Only under special circumstances you would need a 248 Bin made for Pansat Remote, because that BIN is made for a Pansat 2700 remote.
Username: Juancho
La blanca nieve en los..., En las altas... BINDURABLE
Post Number: 2136
no only them, also nikk mty from the hispanish only thread has mods 2 2700a bins following jvvh steps, the last one the 248 is working a lot better than other bins, I said so, as I am using those bins,jvvh is an adviser only, no more bin from him, until now the remote pansats , pantecs or FLus don't have problems whit thah bin
Username: Hoosier_daddy
Post Number: 148
What about for a clone converted...same thing....248T?
Username: Way2smart
Www.desifta.tk
Post Number: 989
yaa but there is pansa2500 and fortec..flu...make sure u get the right file
Username: Nydas
Post Number: 7913
We are talking about matching Remotes with BINs. it matters 2 hoots what your STB was.
A remote is the thing you hold in your hand to control the receiver.
Username: Det
Post Number: 45
where can i download a bin file for a clone pansat 2500 to a 2700?
Username: Way2smart
Www.desifta.tk
Post Number: 991
crazyfta. com
Username: Nydas
Post Number: 7914
m n m:
http://public.box.net/2500_full_kit
Username: Way2smart
Www.desifta.tk
Post Number: 993
or that...
Username: Juancho
Post Number: 2137
I used the nikk bin ,as the other screwup the 247 with the remote problems, then nikk came out with his bin firts 247 bin and also it was better than the others bins, ,from now on , I will sticks to it, go to the hispanish only forum and look for the link or ask for it. more than 24 hours without problems.
Username: Nydas
Post Number: 7922
247 BIN was a passing phase.
The more stable BIN is 248, and the jvvh_FortecRemote_248 or CS_248T_lightning works with most Remotes. If you have a Pansat 2700 remote, use the jvvh_PansatRemote_248
Username: Geeksqaud
I see why there's confusion. Genuine Pansat 2500a owners don't want to use a "Fotec" bin. Maybe they should name the bins differently. I think I'm going to buy 2700 remote for my 2500a convert. There are more buttons on it.
Username: Post_man
Post Number: 43
I have no Problem with my Pansat remote.
Since I flash Bin 248 I have lost Galaxy 25
at 97 and few other channels, I had no problem
with Bin 245. I have tried different Bins
and different loaders from different websites.
Can anyone out there help?
btw what loader do one use with what Bin?
Username: Nydas
Post Number: 7952
Always use BL updater 1.4 with all BINs for conversions.
Username: Imnycusa
Post Number: 114
while using BL updater 1.4, what port# is recommended for a USB-DB9 adapter. Thanks.
Username: Nydas
Post Number: 7999
BL Updater will accept a connection on any of the 4 COM ports 1-4. The problem is that you have to set up the driver software of your USB-Serial adpator, using manual installation and also changing though the Device Manager facility of your computer.
Username: Imnycusa
Post Number: 115
Thanks Nalin.
Username: Kacha
Post Number: 50
whats the new bin for pansat 2500flu? dn
