Re8 vs pioneer TS-SW2541D
Username: Surferdude9371
Im BTL Bumpin
Post Number: 585
which would you guys go with im doing an install on my neighbors truck?
Username: Insearchofbass
Post Number: 7868
whats the budget because I might have a better idea
Im BTL Bumpin
Post Number: 586
he doesnt really know he just wants to keep cost low as possible. has to be shallow mount and no bigger than a 10
Post Number: 7869
I also need to know what type of sound hes looking for and if he has an amp what is it and what is the power at what ohm
Im BTL Bumpin
Post Number: 587
wants sql just did sum remeasuring pretty much needs to b an 8 he doesnt have an amp yet so if you have a match up for both thatd be great
Post Number: 7870
yeah go with the resonant engineering re 8 but check out the sellers feedback
http://cgi.ebay.com/RE-AUDIO-RE8-8-SUBWOOFER-RESONANT-ENGINEERING-SUB-new_W0QQit emZ190196763287QQihZ009QQcategoryZ18802QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
or this single 4 ohm tangband 8 if for some reason it has batter depth measurements and you have to skip the re 8
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=264-854
ill look for an amp next
Post Number: 7871
nevermind I just saw the re 8 has a 4 inch mounting depth so skip the tangband sub
