Pansat 2500A Converted to 2700 question
Username: Geeksqaud
I susccesfully converted a Pasnast 2500A to 2700. Will future updates require bins designed specifically for a converted STB, or will any 2700 bin work?
Username: Nick000000
Montreal, QC Canada
Post Number: 26
always use bins made for 2500 to 2700 Flus
Username: Geeksqaud
Got it. Thanks!
Username: Asharfi
Post Number: 1818
Jake,
Since, now you have a converted Pansat 2500, you must use either JVVH or Chancysand bins. Using the original Pansat 2700 bins will bring your FTA receiver to death.
Username: Pupy
como consigo los bins?
Username: Pupy
necesito el archivo j27_205_1 en donde lo puedo conseguir?
Username: Geeksqaud
Thanks for the clarification AV
Username: Tut22
Hey gus i been thankful to all of u in the past years
i encounterd a prblem i have pansat 3000 i never seen 3000 files any where any idea
Username: Tut22
and do i need a loader to load it in the reciever
Username: Nydas
Post Number: 7879
Tut22: All instructions and files at:
http://public.box.net/2500_full_kit
The full kit is in full_kit_16A.zip or later. Download the kit and unzip in a new jvvh directory. Read the instructions in the Instructions.doc file. Some files can be downloaded separately
Username: Sutkra
Usa
Hello Nalin,
I spent lots of time trying to find answer why my Pansat2500A remote after conversion to 2700 doesn't work even I followed your instructions 100%.
I found on the other site that I need to use 2700 remote now. I was thinking that the bin: Jvvh_PansatRemote_248 does that job, enables 2500 remote to work with newly converted 2700?
Thanks so much if you find a minute for an answer
Username: Metallica
Post Number: 46
hey b..i converted my and my pansat 2500 remote work just fine..
read here for the bin that work with the 2500 remote from Nalin.
https://www.ecoustics.com/electronics/forum/home-video/444498.html
Username: Mxowner
yea u just to charge the propel bin thats all
Username: Sutkra
Usa
Ah Thank you Metallica so much, I missed it somehow, it works now. I only can't find my old satellite I use to watch mostly, That's Galaxy 25 @ 97.0*W. It is not on the list at all, so I guess, I need add it manually or load other satellite list (no ideea which one).
Thank you very much}
Username: Metallica
Post Number: 52
you're welcome bipi.
Username: Luckyabbas
Sukkur, Sindh Pakistan Pakistan
i wanna watch HBO and POGO channels through Satellite receiver but these channels are encrypted so can i watch tehse channels throgh PowerVu Provider ID and Key.....plese help me !
Username: Metallica
Post Number: 54
what reciever do you have??
did you download the new bin yeah??
more infor please i'm kind of lost.
Username: Sutkra
Usa
Thanks everyone especially you metallica, I got clue by loading the other bin (not pansat like I did).
Everything works now.
Now the new quest. Since I have antenna rotor, (watching only Globecast), can I add DN LNB and have combination of DN and GCast LNBs (avoid to have 2 antennas) and watch DNetw. Did anyone try it?
Thanks everyone
Username: One_eye_jack
Post Number: 367
bipi
Just replace your LNB with this Invacom QPH-031
Invacom QPH-031 QUAD LNBF Details
The Quad Polar LNBF, model QPH-031, offers 4 outputs for the reception of both Linear (FSS) and Circular (DBS) Ku-Band, with a 0.3dB noise level! Excellent choice to use with your motorized satellite dish.
Your Dish needs to be 33" or 36"
Username: Kacha
Post Number: 49
is there a new bin out for 2500 flu for DN?
Username: Satgrl
OuTa yeh DuniyA
Post Number: 1443
check it at ftabins in 2500 flu section
