All, My TV UHF/VHF board is not working and replacing that is not worth it(fianacially). Luckily I have 5 RCA(RED, YELLOW & White), 1 Component (Red, Green & Blue) and 1 SViideo free on the back of my TV. My question is does CW600S Premium have a functionality where I can change the video components ? For example I would like to use SVIDEO for satellite and RCA connection for my basic cable By doing this I do not have to use faulty UHF/VHF connection on the back of my TV. If the answer is yes, than how do I change the SVIDEO to RCA from the remote control. How does the CW600S Pe knows that satelite should be on SVIDEO & cable should be on RCA ?
If the answer is no than any suggestion whould be really helpfull. I do not like to introduce a cable box or a VCR to the equation at this point.
Thank you very much for your help and co-operation
'My TV UHF/VHF board is not working' You should be able to use RCA or S-video connections. All you have to do is select the proper TV/Video button on your TV remote or in some cases the AV/SVHS/CVI button. Just keep pushing it until the satellite signal becomes visible on your TV. In some cases you might have showing Video 1, 2, 3, 4 etc. Each one of these will allow the signal to come through. This just provides a path to RCA, S-video and Coaxial output.
The original poster has double posted this question.
The OP question is confusing at best. Basically what the OP wants to know is IF the CW box can do A/V switching in place of his TV which has a fried board.
Answer is NO the CW box is not a A/V switch.
Suggest the OP look into a external A/V switch that has sensor to automatic switch depending on the powered source. Best buy has them.
