New member Username: Samraz972Post Number: 3 Registered: Feb-08 | AMC-3 87' West I have 110, 119, and 61.5 and I want to get another satelite...which satelite should I get? and is it possible to add this to my current fta cool sat box? |
New member Username: Samraz972Post Number: 4 Registered: Feb-08 | anyne? |
Gold Member Username: KirankumarKenya Post Number: 1403 Registered: Oct-07 | you should be able to get it,only problem is you need another dish,then hook it to port 4 on your switch and do factory reset and auto detect and auto scan. get dish instructions for |
New member Username: Samraz972Post Number: 5 Registered: Feb-08 | Thanks, will I need new lnbs? also will any dish work.. and lastly... if I get another receiver. maybe of a different brand what would I need to hook it up.. will any normal wire splitter work? |
Gold Member Username: KirankumarKenya Post Number: 1404 Registered: Oct-07 | you will need another dish and and a single lnb,and dish will work.if you want to connect another receiver then you hook up a cable from the back of your cs7000 to the next receiver.wire splitter is no good. the other option is to get a switch with with 4 or more inputs and 2 or more outputs,and run another cable to your next receiver |
New member Username: Samraz972Post Number: 6 Registered: Feb-08 | Thanks for your help so far... can u tell me what exact wire I need to hook up my receiver from the back im a bit lost.. or what is the switch called with more inputs. |
Gold Member Username: KirankumarKenya Post Number: 1406 Registered: Oct-07 | if you use wire from your set it is a coax cable rg6.i have to look up on switch because i am not so sure |
Gold Member Username: KirankumarKenya Post Number: 1407 Registered: Oct-07 | go to this site.that is the kind of switch you need,you could buy it cheaper on ebay.just get one of these and that should be the best and easiest way out. when you hook up the switch 119 goes to port 1 110 to port others can go in port 3 and 4 http://sadoun.com/Sat/Products/S/S-SM24-2x4-multi-switch.htm |
New member Username: Samraz972Post Number: 7 Registered: Feb-08 | DirecTV dish with Triple LNB ( 119, 110, 101) will this one work for the signal I want? |
Gold Member Username: Saqeeb9000Post Number: 2161 Registered: Oct-07 | SANA IF YOU ARE ADDING SAT.... ADD 91 TO IT LOTS OF CHANNELS..... |
