Username: Imars99 BRAMPTON,
ONT
CANADA
Post Number: 49 Registered: Aug-06
Saturday, February 09, 2008 - 01:47 GMT Which file is working for Bev on pansat 2700A?Thanks.
Username: Survayman12 Post Number: 20 Registered: Jun-06
Saturday, February 09, 2008 - 01:48 GMT 237
ONT
CANADA
Post Number: 50 Registered: Aug-06
Saturday, February 09, 2008 - 02:01 GMT Thanks Robert
Username: Rsjrahey North sydney,
Nova scotia
Post Number: 6 Registered: Jan-08
Saturday, February 09, 2008 - 03:13 GMT WHERE DO YOU GET THAT BIN
Username: Rtap FL
Post Number: 1839 Registered: Jan-07
Saturday, February 09, 2008 - 03:16 GMT crazyfta .com
Username: Madhudsstester Post Number: 27 Registered: Nov-07
Saturday, February 09, 2008 - 05:21 GMT I have 2700A and i put 237 but still its not working? any help?
Username: Ozziejatt Post Number: 57 Registered: Nov-06
Saturday, February 09, 2008 - 05:37 GMT Madhu, Did u ever factory reset your pansat 2700a, if yes what files did you loaded after to make it working? Or did a fresh install?
Nova scotia
Post Number: 7 Registered: Jan-08
Saturday, February 09, 2008 - 05:40 GMT yes the same with my 2700A thin nimic went wacky on me and thin went blank and shut down
Nova scotia
Post Number: 8 Registered: Jan-08
Saturday, February 09, 2008 - 05:43 GMT i put the 248 bin back in and i got back some channels
Username: Madhudsstester Post Number: 28 Registered: Nov-07
Saturday, February 09, 2008 - 05:47 GMT I did factory reset then i installed X-87BL_080115_B75_237_api.bin just like all the time i do.
Username: Ozziejatt Post Number: 58 Registered: Nov-06
Saturday, February 09, 2008 - 05:53 GMT so that means no need to install B75 boot file. Menu-Factory Reset-ok and then install Current File (when released) Now do i run blind scan? or what u normally do?
ONT
CANADA
Post Number: 54 Registered: Aug-06
Saturday, February 09, 2008 - 06:09 GMT 236 also working on Bev.
