What Happens if I .........................Pansat 2700a
Username: Ozziejatt
Post Number: 56
Hi there!
Can someone help?
Q: What happens if i factory set Pansat 2700a (i believe it will reste to day1 when bought) next thing what files do i need to make it working again/to watch Dish network?
Why i want this? I need fresh install and rescan all channels again, Even after current working file load i dont get all channels
*** i know dish now is down but instructions from you will be followed once new fix release**
Username: Jwl1
Post Number: 113
I have 2500a converted to 2700, so if I do a reset, I have to do the antenna set up, and scan 110 & 119. However, I scan all, not blind scan. In addition, if I did a reset, I would just have to use the current file.
If I had the issue you did, I would first try deleting all the channels and then do a scan.
I know if the settings are off, it could affect the channels in regard to not getting them all. At least that has been my experience.
