I am getting an "E029" message on my CW 600s...
Username: Kellergirl
Post Number: 24
While trying to load the new bin, the receiver (A Captiveworks 600S) says "E209" on the front. What am I doing wrong?
Username: Dimwitt
Post Number: 402
i would start over, with new loader 105 and a new 165 bin.
Username: Ez2ctv
Platinum Mem...
Post Number: 40
E029 (also E011) is a communication error between your computer & the STB.
Check you cable (it is a NULL MODEM isn't it) for damaged pins or damaged wire. Also the cable plugs may not be 100% seated into the recpticales.
Are you using any adapters between the cable and your computer?
Username: Brucester
Post Number: 1193
killer for the 5 or 6 time some 1 has told you what to do get a new cable or get the adapter you told use yesterday you got cable from friend so now that you get that e209 you no you have the wrong cable get a new one or the adapter and it will work you can not tell the 2 cables apart from looking at them
Username: Doreenakadj
Ontario Canada
Post Number: 1161
keller i got the same error when i flashed a friend receiver this morning
try this
HOW TO FLASH.
You can flash (load) your receiver with a bin on top of the bin (file) you already have. It will replace it.
Use a Null CABLE RS232 on your receiver from the computer. Or use a Null adaptor from Radio Shack number 26-264B to make a straight through cable a Null cable. Take the cable off going to the LNB to be safe. If you don't have a 9 pin plug on your computer you may need to use a USB to Serial cable 26-183 at Radio Shack with a Null adaptor. If you need a 9 pin mail to mail gender adapter it is item #: 26-231. You will need to install a drive in your computer for the USB cable.
Un-zip all the files and hook up the cable from your computer to the STB, have the STB off with the switch in the back. Start the loader and click on the FILE folder. Find the bin file you un-zipped that now ends in BIN. Click on it and it will automatically go in the loader. Select DOWNLOAD S/W then select a COM PORT. You can flash several ways, this is one way and does work. NOT on the remote but in front of the receiver hold in the power button as you turn the switch ON in the back. The word BOOT will stay on the STB front panel. Now you can click START on your loader and the % should move up. Or you can flash in the standby mode. Standby mode is when you have the receiver ON in the back and OFF with the remote. You will see the time or --:-- if there is no time. Don't do anything as the progress bar is going across. Make sure the Computer & STB are done before you go to the next step. They may not get done at the same time. The receiver needs up to one minute to process the data after the computer is done, (DON'T RUSH THIS). The receiver will count down twice then show "-End". When done turn receiver OFF & ON from the back. You may need to do a FACTORY DEFAULT instructions below.
Post Number: 25
I did it!!!!!! What happened was the guy at Radio Shack gave me the wrong adapter, so I took it back, and another guy gave me the right one. Thanks a lot everyone for all the help...I really do appreciate it!!!!!!!!!!!!!!!!
Username: One_eye_jack
Post Number: 356
Very nice Doreen, but I though that
bruce 1 was the man for CW receivers
Ontario Canada
Post Number: 1163
TEEHEE and you all thought you know me so well
computers and receivers are my hobby even though I am born a girl I am very much a tomboy and btw YES i have all my girly parts still in tacked and working very well contrary to what some DUMBASSes thinks of me in this forum.
Ontario Canada
Post Number: 1164
speaking of bruce .. I still want him to update the loader on the completefta site. I have 107 loader but on the site they still have 106 in the stickys I would do it myself but it still wont let me upload anything.
Username: Brucester
Post Number: 1195
doreen i can not load files on that site im a member just like you ill ask some on to put it on the site i have it at crazy but ill ask for you at complete and fill free to help any one you want i thought he had the wrong cable told him 2 days ago but glad to here it is all good for him
Username: Brucester
Post Number: 1197
doreen you can go read the ancer i got at complete it is in the cw600p chat section
Ontario Canada
Post Number: 1167
"your info CW has not released any new loaders, that is probably a modified loader renamed for another site, we deal closely with CW and if they release new loaders we are notified right away"
that is so not right ... look at the size difference between them 105 size 856kb 106 size 508kb 107 size 852kb
I agree with you 107 is way faster
Ontario Canada
Post Number: 1168
ask this guy about the size difference and maybe he should go check it out b4 he says anything
Username: Brucester
Post Number: 1198
i ask and it is the skin thay say lol
Ontario Canada
Post Number: 1169
well they are WRONG lol 106 and 107 look the same but file sizes are way different 105 is closer in size to 107
Username: Brucester
Post Number: 1199
i think so but if i keep bugin them there going to band me lol i told them but you or your friend can get it from crazy i put them in last week
Ontario Canada
Post Number: 1170
i've had it over a month or so now i got it from satscanner in my msn
Username: Newfie1949
Post Number: 26
Doreen you didn't need to use so many word to
flash a captive works receiver. If you had anything
upstairs you could of said everything in two sentences. But again you are trying to be something
that you are not. Let me tell you something (he-she)
LK is the man around this sight and many others sights. If you were not such a @SS O maybe LK could
of thought you everything about fta. Didn't you
know LK is god. Thats right god. LK is so good
Doreen that he could of fixed that s*ex problem
you have. Doreen, I understand that you are going
on CNN Larry King show. Are you going to pull your
dress up and show the world the ballsack you have
between your legs with the ni*p*ple on it? Will
anyhow Doreen you have a good day, and god bless
you, B!tch.
Username: Brucester
Post Number: 1203
newfie dont come start sh it in other peoples thread start your own thread and maybe you can help out instead of bashing all the time just a thought have a good day
Post Number: 28
Sorry, Bruce l. You are right. I just don't like
Doreen, (He-She) go me pizzed off. I don't have a
beef with you or anyone else, except that B1tch
Doreen, who thinks that her sh*it don't stink.
Like I said-SORRY to all other members.
Ontario Canada
Post Number: 1173
well newfie... I don't like you either, but i don't troll the forum stalking people either making up storys about you like you do me. Stay away from me and I'll do the same for you. like bruce says have a good day.
Post Number: 29
OK Doreen, you got a deal. Don't you post anything
anywhere on any thread thats dealing with me and I
will stay far far from you. But if you try to screw
with me again, not only will I cut your ballsack off
but I will also cut your tits off and make you play
the bone a phone. And like Bruce says Doreen you
have a hell of a day and I hope that one thousand
fleas of a camel invade your puzzy, ballsack and all you B!tch.
Ontario Canada
Post Number: 1174
Well newfie I can't stay away from threads that I know I may offer any help in. But I won't make a personal post regarding you if it happens you are posting in the same threads. How's that? As for your comments regarding my privet parts and ones you've dreamed up.... YOU'RE MAKING ME LAUGH.
UploadA
Post Number: 31
Ok sister, You want Peace, You have it. If you are
not rude to me anymore I will not be rude to you
or any other person. Iam glad that you can laugh
it off. The war is over. Long live the PEACE.
Also LK I know that you are using other nick again
I think that you also should make peace with everyone. You are a very smart man, and I give you
your due for that. But you need to be nice to people. Loving on people is far better than running people down. Love never fails. And Iam
not talking about s*ex. The love that Iam talking
about is this kind-now the fruit of the spirit is
love, joy, longsuffering, kindness goodness,
peace, gentleness, and self-control.
