2500 converted to Hell!
Username: Luser
Post Number: 52
Do I now look for new bins under 2700 and if does that apply to other files like channels as well or should I just see how far I can throw it?
Username: Psychmonster
Rhodium MemberAint nuthin ...
Post Number: 722
HUH?
Username: Hoosier_daddy
Post Number: 152
There will be bins that say they are for converted 2500 - 2700 look for clone safe if it is a clone you r using.
Username: Metallica
Post Number: 68
wait for the bin..don't throw it yet until i say so.
Username: Asharfi
Post Number: 1828
Semore Butts,
Those converted Pansat 2500 receivers need JVVH or Chancysand bins. You will kill your receiver if you use the original Pansat 2700 bin. There are no working bins for those units as of now. All Dishnetwork channels are down, but BellExpressVu is working with some old bins.
Username: Luser
Post Number: 53
OK thanks! another 2500 saved!
Username: Saado7
Post Number: 24
u know what bin works for bev on the 2500 ??
Username: Nydas
Post Number: 7991
As of now, on Converted 2500 CS_237 or jvvh_237 works for BEV only.
Username: Saado7
Post Number: 25
thnx nalin
