Nalin....Please Assist !
Username: Edmundk
Newmarket, Ontario Canada
Post Number: 13
Nalin,
There are 3 Bin Files 237 namely CS237_Lighting, Jvvh_PansatRemote_237 and Jvvh_FortecRemote_237.
Which Bin file we should use for Pansat 2500 converted to 2700?
Just downloaded CS237_Lighting which doesn't seem to work. Please enlighten.
Thanks!
Edmund
Username: Snw7619
Bahamas
Post Number: 192
dssh is down so none will work
Username: Snw7619
Bahamas
Post Number: 193
but CS was working
and Pansat remote for 2700 remotes
Username: Edmundk
Post Number: 14
Thank you for your input. Do you mean CS_Lighting237 only works for real Pansat 2700, NOT for 2500 to 2700 conversion? if this is the case, then for those who have Pansat 2500 converted to 2700 on Dishnet have nothing to see, until a new BIN file is release. Please explain.
Username: Perycles2005
Post Number: 65
Any of them will work with your pansat converted...however, right now due to a new ECm is not going to work anyone...just be patient until new bin is released ( it should be CS lighting 249 or jvvh 249
