This is crazy but here it goes
Username: Big_fletch
Newport, Ar, Ar United states
Post Number: 696
i ordered (4) kicker cvr 12's and im going to get a 18" Mach audio MJ for 116$ now my question is how could i get all subs moving on 1 amp? do i need a 1 ohm or 2 ohm stable amp and what kinda watts?
i also know that mixing subs is a mistake but im going to do it so could u tell me a way
Username: Surferdude9371
Im BTL Bumpin
Post Number: 630
what ohms are the subs?
Username: Killerzracing71
Fredericksburg, Virginia United states
Post Number: 1945
First off Y
get another MJ 18 that will look so ghey i hat setups like that
Username: Denali_on_22s
The kids like my rhyme...
Post Number: 4086
that will look like sh!t and probably sound worse.
Username: Insearchofbass
Post Number: 7944
you also didnt say what amp your using and the ohm its stable to and you better make sure you have the room for all those subs
Username: Nickyp0219
Post Number: 625
post a video lol
Im BTL Bumpin
Post Number: 631
sean i think hes asking what amp he needs
Post Number: 7946
opps im slippin today....your right P. rick
Post Number: 697
lol yea its going to look like crap for sure but yea im asking what amp should i use and the kicker subs are dvc 2 and the mj is either in 8ohm or 4ohm single i havent bought it yet
Username: Nyyfan13
15 MAG USA
Post Number: 8361
How do you have 700 posts here and not know its a dumb idea.....
Post Number: 4100
no joke...
Username: Big_edge_head
Milwaukee, Wisconsin MY SUBS GET ...
Post Number: 1442
cant believe what im reading
Post Number: 7953
you no im thinking it so im going to say it ....what do you hope to gain by getting an 18 to go with the four 12's if its the lows the 12's are already going to hit the lows just fine
Post Number: 7954
powering the four 12's will be enough anyway esp if your not upgrading your alt. which I would do anyway powering them
Username: Nd4spd18
Northwest PA
Post Number: 6155
" now my question is how could i get all subs moving on 1 amp? "
Answer is no....... /thread
