Get 118.7 Using 119!!!
Username: Way2smart
Www.desifta.tk
Post Number: 1141
http://cgi.ebay.ca/DUAL-CIRCULAR-LNB-LNBF-CB2008A-FTA-118-7-DISH-119-118-8_W0QQi temZ150213166732QQihZ005QQcategoryZ149971QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
all u need to do is buy this converter that will catch both 119 and 118.7......
Username: Saqeeb9000
Post Number: 2119
i will check with shafeeq...
if he has any...
Username: Way2smart
Www.desifta.tk
Post Number: 1142
im ganna check with FX and see ill let u know 2morro ok....
Username: Kirankumar
Kenya
Post Number: 1343
$mart,
what size dish do you need for this set up?
Username: Madflea168
Post Number: 214
believed the requirement for 118 is the bigger the better, at least 30 inches.
Username: Vittu
Post Number: 150
will I be able to get 118 on a 24x18? Has anyone tried it?
Username: Nydas
Post Number: 7964
Vittu: TThe dealer at a flea market told me not to use 18 x 24 for 118.7 - he suggested I might try the 18 x30 dish, but was not sure.
Username: Cybermaster
Post Number: 118
Isn't this shitt is the same? http://cgi.ebay.com/Combo-DSS-Circular-Dual-LNB-LNBF-Dish-119-118-8-Anik-F3_W0QQ itemZ360021765812QQihZ023QQcategoryZ32844QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
low noise figure too and easier to mount.
Username: Nydas
Post Number: 7984
There is a CB2008 and CB2008A and then there are two better replacements of these.
