Bat Cap How is it used exacly ???
Username: Tpa954
Hollywood, Florida U.S.A
Post Number: 90
I just purchased a BatCap Xstatic 300 , i was wondering how exacly is this used more like a battery or a capacitor ??? And also how would i run the wiring,(Diagram Would be very helpful) Thank For the Help .
Username: Tpa954
Post Number: 91
I got wiring diagram but still dont know how this is diffrent from a cap or battery still need explanation, THX.
Username: Nd4spd18
Northwest PA
Post Number: 5078
Read the last paragraph on this page:
http://www.glasswolf.net/caraudio/capacitors.html
Username: Tpa954
Post Number: 96
So a batacap is a bad idea then ????
Username: Nd4spd18
Northwest PA
Post Number: 5093
I would use a normal battery instead. If you use it though just wire it like any other batttery.... I don't see the problem.
Username: Big_edge_head
Milwaukee, Wisconsin USA
Post Number: 1069
dj the owner of audioque has 2 10'' hd3s(correct me if im wrong) and he also has 2 batcaps(not sure of the model number.) he dosent have a HO alt. ither. and he says its just fine.
Username: Insearchofbass
Post Number: 7894
on batcaps site the have like two ways to hook the batcap up one is better than the other
Username: Nd4spd18
Northwest PA
Post Number: 6096
Way to bump a month old thread.......
Post Number: 7902
I missed that...oh well haha
Username: Th3pwn3r
Post Number:...
Post Number: 6805
Lol....
