LNB Single Stack and Pansat 2700A
Username: Mafri
Post Number: 12
I Installed the new LNB to receive both sattelites ( 119 and 118). But when i want to insert the new Frequencies, with the Pansat 2700A it is impossible! What can I do to change the Frequencies?
Username: Kirankumar
Kenya
Post Number: 1412
what size dish do you have,it has to be at least 33"or bigger
Username: Poscor
Post Number: 91
also i believe that you do antenna setup anik F3 for the 118 sat and use the same diseqc port as the 119 sat.
lnb type universal.
