HELP, my stroker subwoofer wont work.
Username: Bryanwalsh524
Post Number: 53
It worked fine i had it for about a month and a half. then one day it didnt work. everythings hooked up correctly. we used one of those power light checking tools. every connection lights up from everything running into and from amp and the wires running to the box. my friend said my sub might be overheated? would this be what is wrong with it, is their any way i can fix it or what. thanks.
A pic is worth 1000 posts!!
Post Number: 13240
Overheated? Does the cone move freely? Any scratching? Are the tinsels still attached? Did you try another sub on your amp?
Username: Big_edge_head
Milwaukee, Wisconsin IF IT DOESNT...
Post Number: 1381
does it smell like burnt resistors and electronics?
Username: Ska
Post Number: 316
did you check your fuses?
Post Number: 13258
Did you check your underwear?
Post Number: 13260
LOL. Where are you?
Username: Rovin
4 10 Pioneer...
Post Number: 13019
have u tried stroking it ?
Post Number: 54
the subwoofer doesnt move at all. no it doesnt have any particular smell. dont have another sub to try. fuses are fine i checked that first. whats a tinsel?
Username: Stateprop486
PA
Post Number: 306
mayb blown stroker? ....
Username: Bonhamd
Northern, Michigan USA
Post Number: 207
not usually a good sign if it doesn't move
Username: Kravenblood
Ohio Hmmm
Post Number: 371
So you push down on it and it dont move more than likely its blown just call em up and get a recone kit its fairly simple to do just be carefull not to break the ring or strip the screws like i did.... what amp are you using whats your electrical system like is your box ported..sealed
Post Number: 13310
Yeah if it's as stiff as a corpse then it is one.
