Username: Dupe112309 Post Number: 31 Registered: Feb-08
Monday, February 11, 2008 - 01:19 GMT type r components for the front and type r for rear too...fronts put out 90w and rears 100w rms. would the pdx 4.100 be a good setup altogether? along with a 16 ga amp kit
Username: Philly306 I get higher golf scor...,
North carolina
Post Number: 845 Registered: Apr-07
Monday, February 11, 2008 - 01:25 GMT 16 ga amp kit? do they really make those? theres no way yea that should be fine but u need something like a 8 gauge kit and speakers are rated for power handling, they don't "put out watts"
Username: Dupe112309 Post Number: 32 Registered: Feb-08
Monday, February 11, 2008 - 01:56 GMT ok the fronts are rated at 90 and the rears 100 sorry phil. but 8 ga will be fine?
Username: Bnd_rulez Phoenix,
AZ
Post Number: 1449 Registered: Mar-05
Monday, February 11, 2008 - 14:44 GMT 8 gauge power and ground wire will work perfectly. The you can use some 16 gauge speaker wire to actually hook up to the speakers from the amp.
