Username: Ss22 Post Number: 5 Registered: Jan-08
Wednesday, February 06, 2008 - 00:59 GMT wat sub to get out of a kicker 15" l7 2ohm or kicker 15" l7 4ohm and wat amp to go with them
Username: Nickyp0219 Post Number: 499 Registered: Jun-06
Wednesday, February 06, 2008 - 01:01 GMT surely you can get better for the money...if you want to of course post budget and what you want out of it, sq, sql, spl someone here can help you
Username: Drivingreckless DD 9515f,
148.2 db Mov...
Post Number: 5364 Registered: Apr-06
Wednesday, February 06, 2008 - 01:01 GMT why only those two? whats your budget? what are you looking for in a system?
Username: Ss22 Post Number: 6 Registered: Jan-08
Wednesday, February 06, 2008 - 01:36 GMT i want spl subs and my budget is $800-1000
Username: Ss22 Post Number: 7 Registered: Jan-08
Wednesday, February 06, 2008 - 01:38 GMT i wanted the loudest bass and budget 800 to 1000 and wat other subs do yu suggest
Username: Jnoel AIM= j69noel,
KY
Post Number: 950 Registered: May-07
Wednesday, February 06, 2008 - 01:45 GMT man you could do a dd9918c with a orion 2500d for that price range as long as you got the electrical to support it....... that was my old setup and it was pretty dayum loud...........
KY
Post Number: 951 Registered: May-07
Wednesday, February 06, 2008 - 01:46 GMT i personally dont like l7's but it's your money....there is alot better for the money you state in yoru budget
