1. Take some 100% Sulphuric acid and mix in hydrochloric acid. 2. Dip the file in the mixture and leave it in for 10 seconds. 3. If it is still there it is a virus - don't use it. 4. Otherwise get another copy from the same site and use it - presuming somebody has not posted new one.
The other alternative is prayers first. Almost everything is OK afterwards, unless God missed your prayers, because he had gone to a bad site to root out E V I L.
come on Nalin, why are you doing this,no need for it,we have enough bad guys here.
devin, the best bet is to g to the home site of your receiver and download the file with the latest date.make sure there is no ecm at that time.if you have a clone make sure you download the file for clown.that's how simple it is.good luck
