Alpine type x components
Username: Dupe112309
Post Number: 9
lookin for components in my front, was looking at type r's, but heard type x's were better, but there's no coaxials for type x's to put in my rear, so was thinking about putting type r's in, any other suggestions? would a component system in the rear be bad?
Username: Adddisorder
Palm Beach, Florida
Post Number: 5876
dont run rears, that simple
Username: Ewok
Fairbanks, Alaska U.S.A.
Post Number: 11
components are for the front.
Palm Beach, Florida
Post Number: 5880
your fine to run componetns over coax in the rear but read this article why you dont need rear speakers. http://glasswolf.net/caraudio/rearfill.html
Post Number: 10
ok so if i put type x components in the front and then type r's in the rear, would that be okay since the rms doesn't match up?
Palm Beach, Florida
Post Number: 5885
yeah you can do that if you want or just put componets in the rear. personally i wouldnt do either.
Post Number: 13
what about putting some midbass speakers in? i'm lookin for something to go in the back of my mustang cpe. probly will run a 12" type x sub (1000w rms)
Palm Beach, Florida
Post Number: 5890
get get a type x sub they arnt worth it. you can put midbass in if you want you can put type r in the back im just giving you a suggestion for better SQ.
Post Number: 14
what do you suggest for a sub/subs? probly lookin for something about 700-800 for sub/subs and amp. lookin for sq while also hittin decently.
Palm Beach, Florida
Post Number: 5895
stereo integrity magnum on 1-1.2k rms
Username: Exige
Post Number: 106
x2
