Pansat 2500a conversion to 2700
Username: Jwl1
Post Number: 103
I loaded the latest bin, and my remote is not working. However, I don't see any other postings with this issue. Therefore, what went wrong?
Username: Metallica
Post Number: 28
Joe go back to (Nalin--please clarify) thread i already answer your question.
Username: Jwl1
Post Number: 105
Thanks Metallica--I saw that you did respond after I posted this.
How can two bins made by the same person be different? Meaning, why does one work, and the other one doesn't? I always thought they were the same, just that you got them from different sources, as long as same bin/file number and maker.
In addition, I appear to be the only one that had a problem with the remote issue, and I assume others used the same source. So, that leaves me puzzled.
Username: Metallica
Post Number: 30
Joe..i don't know why either..i had downloaded 30min ago now i am watching all the DN channels with the new bin..
BTW try to press the SAT/TV on your remote see if it work if not reload the Jvvh 248 again.
Username: Jwl1
Post Number: 106
Metallica--I've come to the conclusion that the file was labled wrong. I always test the same bins made by the same person.
Since there was an issue with this bin for the very first time, I did load the other one (which is by a different maker) and all is fine.
Thanks!
Username: Metallica
Post Number: 31
you're welcome:-)
Username: Nydas
Post Number: 7893
Which Remote?
According to the jvvh_248 instructions:
"Pansat 2700 remote users still use the Jvvh_PansatRemote_248 bin.
Pansat 2500 / Fortec / Pantec Remote users will have to use the Jvvh_FortecRemote_248 bin."
The CS_248T_lightning is also working fine.
