Cools*t 5000 programing cable connection
Username: Deepam
Post Number: 7
Did any one help me how to make new programing cable for coos*t5000.. how many wires to connect and which pins to connect.. thanks.
Username: Nydas
Post Number: 7892
In this particular situation, you might be better off buying a DB9 M/F null adaptor ($5). Then you do not have to remember the cable type. One cable only. Use it in series for one type of work and do not use it for another type of work.
