Silver Member Username: SkaUSA Post Number: 262 Registered: Jan-08 | The amp is an American Bass XD1800. it does 1800x1@1ohm and would provide plenty of power for the 10" IDMAX. The amp also comes with a remote bass knob so you can adjust the level of bass from the drivers seat. I would do $500 + shipping for the pair. what do you guys think? |
Gold Member Username: DrivingrecklessDD 9515f, 148.2 db Mov... Post Number: 5374 Registered: Apr-06 | 500+ shipped for the id max and xd1800? |
Silver Member Username: SkaUSA Post Number: 264 Registered: Jan-08 | Yea |
Gold Member Username: DrivingrecklessDD 9515f, 148.2 db Mov... Post Number: 5377 Registered: Apr-06 | sweet deal... |
Silver Member Username: SkaUSA Post Number: 265 Registered: Jan-08 | really? driving is that you on ca.com? |
Gold Member Username: DrivingrecklessDD 9515f, 148.2 db Mov... Post Number: 5380 Registered: Apr-06 | im drivingreckless on CA.com |
Gold Member Username: Denali_on_22sThe kids like my rhyme... Post Number: 3865 Registered: Feb-06 | that's WAY too much power for an IDMAX unless you can run that amp at 2 ohms |
Silver Member Username: SkaUSA Post Number: 266 Registered: Jan-08 | I was thinking that seemed like alot of power... evenn if the amp could run at 2 the sub is duel 2... |
Gold Member Username: Nd4spd18Northwest PA Post Number: 6024 Registered: Jul-06 | No such thing as too much, just set the gain according to how much power you need. But that amp does have more power than you need. |
Silver Member Username: SkaUSA Post Number: 275 Registered: Jan-08 | what kind of alt will i need for this amp then? 160amp? |
Gold Member Username: Nd4spd18Northwest PA Post Number: 6028 Registered: Jul-06 | 200+ amp would be ideal |
Silver Member Username: SkaUSA Post Number: 280 Registered: Jan-08 | what would be a fair price for a 200 alt? |
Silver Member Username: TreezPost Number: 162 Registered: Aug-06 | It depends on how much your're willing to spend. I had 2 10 idmaxes running off a Jl audio 250/1 before i upgraded to a 500/1. They're super efficient> Even with that little power those subs had so much impact... |
Silver Member Username: SkaUSA Post Number: 282 Registered: Jan-08 | are they a real SQ driver? like i wouldn't care if it didn't hit over 120 dB as long as it sounded perfect thats all i really want |
