Help with DVI input
Username: Smokelaot
I have a digital DVI input...my goal is to connect my laptop to my hdtv via the dvi to vga adaper. I bought an adapter with both digital and analog capabilities. My question is can I use pliers to remove the four prongs that surround the wide prong to create a digital adapter? If so will this effect performance at all?
Username: Popemogoth
Dallas, Tx US & A
ANY HELP?
Username: John_s
Columbus, Ohio US
Post Number: 2104
No, that won't work.
This will:
http://www.networktechinc.com/press-vga-dvi.html
