HO alt quote
Username: Bonhamd
Northern, Michigan USA
Post Number: 152
Hey guys - this is a quote from iraggi. These prices seem high...Any ideas?
What do you recommend to run around 2500 rms using 1/0, big three upgrade, but no extra batts.
180 $399
200 $419
220 $539
240 $559
260 $579
280 $599
300 $619
Username: Denali_on_22s
The kids like my rhyme...
Post Number: 3868
just get a 260 amp alt. it will cost about the same as buying an alt and a bat were yout o get the 200... honestly for 40 more bucks i would just get the 300 so you can have wiggle room.
Post Number: 3869
not to mention iraggi has been known to make some overrated alts. well, at least from a couple of people i've talked to.
Username: Nyyfan13
15 MAG USA
Post Number: 8232
I personally would contact other companies. I have heard many horror stories about Iraggi.
Enter Jesse's story.
- Yanks Fan
Username: Bonhamd
Post Number: 153
ya i remember reading Jesse's tread...What do you guys recommend? Ohio is expensive right? what about db? any others?
Username: Insearchofbass
Post Number: 7820
if your using this for a daily setup you might want to get a smaller alt with a higher idle amperage ...I dont think the 300 amp alt has as much idle amperage as the smaller ones iraggi has but 2500 watts will be about 220 amps to 232 amps
Username: Nyyfan13
15 MAG USA
Post Number: 8235
http://www.powermastermotorsports.com/
http://www.ohiogen.com/
http://www.db-starter-alternator.com/
http://www.mean-green.com/
http://www.excessiveamperage.com/
http://www.highoutputalternator.com/
- Yanks Fan
Username: Bonhamd
Post Number: 154
alright so maybe a 240 to be safe? what companies?
Post Number: 7821
my bro had to send his 300 amp iraggi back once ...it was bad out of the box but the next one he sent is still working fine
Post Number: 7822
what im saying is get the highest idle amperage you can get not the max rating but go larger if the idle amperage stays the same but the max rating goes higher
Username: Bonhamd
Post Number: 155
ohh i see. what companies should i get quotes from then?
Post Number: 7823
all of those listed by yanks fan are good but make a point to ask what the idle amperage rating is
Username: Bonhamd
Post Number: 156
k thanks guys
Username: Nd4spd18
Northwest PA
Post Number: 6026
Take out EA and add motorcityreman.com
THEN all those companies are good
Post Number: 7830
so EA has a bad rep now M.S.
