What is a slot port?
Username: Surferdude9371
Im BTL Bumpin
Post Number: 545
im designing a new box and dont get the diff between
a square and slot port?
Los Angeles, CA
Post Number: 17769
slot port uses the wall of the box as the port.
Los Angeles, CA
Post Number: 17770
like one of the port wall will also be the wall of the box. lol. did you get that? kinda confusing myself here. lol.
Los Angeles, CA
Post Number: 17771
Im BTL Bumpin
Post Number: 546
would this be slot port?
Los Angeles, CA
Post Number: 17773
i don't think that is a slot port. even though you are using part of the wall of the box as a wall of the port, its not using the whole side.
Im BTL Bumpin
Post Number: 547
ok thnx
Username: Nyyfan13
15 MAG USA
Post Number: 8211
Im BTL Bumpin
Post Number: 548
this one?
Los Angeles, CA
Post Number: 17774
which is the port opening?
Im BTL Bumpin
Post Number: 549
red is opening
Los Angeles, CA
Post Number: 17777
oh ok. i would consider that a slot port then.
Im BTL Bumpin
Post Number: 550
thnx trying to calc port lenth
Username: Phil_salisbury
Post Number: 511
A slot port vs sqaure port is the same thing, the only difference is the slot is Square ( all sides being equal ) vs slot rectangle ( unequal ) plus it has nothing to do with whether the walls of the enclosure are or are not used.
I've built enclosure's with " slot ports " that used square, rectangular,tri angular and trapizoidal that did or didn't use any walls of the enclosure's, what are/were they called???
A port is defined merely by how it appears as to it's shape just like a Horn, Folded Horn or Transmission Line, Flared and so forth, different types of ported cabinets given their description of design.
Im BTL Bumpin
Post Number: 564
so if its 6.5x20 it would be a slot?
Los Angeles, CA
Post Number: 17790
wow i always thought slot port was when the port is off to the side of the box sharing the wall of the box. you know like a slot. but after doing some research, phil is right. slot port just means a rectangle port.
sorry p.rick, i gave you a misinformation.
Im BTL Bumpin
Post Number: 565
no prob man i appreciate the help so 6.5x20 would be a slot?
Post Number: 513
Well, yeah, you can all it a " slot port " because that's what it looks like, but, it's still just a " port " just rectangular in shape.
Think of it this way:
People don't call a round port a " circular port " anymore than they would call a slot port a " rectangular port ". it's just easier to say " round, square or slot ".
And just because the walls of the enclosure are used to create a port doesn't make it any different as what it's still called.
Im BTL Bumpin
Post Number: 567
im talkin bout it to find port lenth on this site http://www.carstereo.com/help/Articles.cfm?id=31 ?
Post Number: 514
Just key in the info it is asking for and it spits out the info ya need to get the length.
However, that calculator does not account for port wall displacement and without that your port length will be incorrectly calculated.
But, in the grant scheme of things it won't be thrown off by any great degree that you will/would notice the difference.
Im BTL Bumpin
Post Number: 568
ya but i mean how do i know if to select square or slot port?
Username: Insearchofbass
Post Number: 7788
"However, that calculator does not account for port wall displacement"
thats easy to figure out if you mean end correction....for every turn you would subtract half the ports width from the total length... say the port calculator said a 20 inch long port and your ports width is 4 and you had one turn you would make the port 18 inches long (just for examples sake)...its not an exact calculation but works very well for me
Im BTL Bumpin
Post Number: 569
do i select square or slot for 6.5x20?
Post Number: 7789
slot
Im BTL Bumpin
Post Number: 570
thnx
Post Number: 515
I'm not talking about " end correction factor " and quite frankly, " ECF " is a completely waste in my opinion given the little notice in change to the port for the bass response peak & dB cutout, especially for " daily " listening.
If he's " competing " with this setup then I would say, yeah, slight variation changes in port length to tweak the tuning vs spl output make all the difference.
Also, you don't subtract from port length when you make a turn, port length is port length along the centerline of the port and that never changes till the end of the port inside, then you do the " ECF " mickey mouse nonsense.
Post Number: 7792
"Also, you don't subtract from port length when you make a turn, port length is port length along the centerline of the port and that never changes till the end of the port inside, then you do the " ECF " mickey mouse nonsense."
I knew that I was just making it simple
Im BTL Bumpin
Post Number: 571
im so lost im not competing with this setup just daily driver.
Post Number: 7793
its ok you can follow what ive said ...it works and tunes just fine for me
WEST COAST RD AUDIO
Post Number: 17796
just as long as you are in the vicinity of your tuning, you are good. besides your ears are the best tools when going for daily driver. that is why i told you patrick to go with a port you can adjust. trying various tuning to see the best results is the best.
also the car's accoustics affects the where your sub peaks out so even though a company might recomend certain tuning, it might not be ideal for your car.
Post Number: 7794
personally I can hear where my port is tuning when I run test tones through it one at a time
WEST COAST RD AUDIO
Post Number: 17797
nice. you must of messed with it alot sean. cool.
still in search of bass? lol.......chad
Post Number: 7795
lol you know I thought about changing my name insearchofbass doesnt fit anymore...I can without losing my current account right
WEST COAST RD AUDIO
Post Number: 17798
yeah you can't. just keep it. its cool.....
Im BTL Bumpin
Post Number: 572
its ok i havents surfed in years just what im used ta using
Post Number: 7796
^^^haha
