Ariza 700 Problems
Username: Tomek985
I'm pretty new to the Ariza scene and so far I am able to successfully load newest bin (ariza_700s_h20080202_317e_MINGO) and I power scanned to get channels but I am greeted with constant message (Data is being updated) and no end to it. I turned on AutoRoll for all options and I see no way to fix it. I have 3 echostar sats and 1 globecast diseq switch.
Thanks in advance for any help.
Username: Burnabyh
Toronto, On Canada
Post Number: 33
317 worked fine but now B3V is down.
Username: Tomek985
So I guess I'm just out of luck and need to wait for new BIN?
Thanks for the Response
Username: Aysa
Toronto, On Canada
Post Number: 23
data is being updated means that the receiver is trying to get the codes. turn off your autoroll and only keep the keycode option on...also try going into nagra 2 and just pressing ok...it might work......
