FLU Remote Key Converstion Table
Username: Moboneii
This is a little excel program I made to help speed up inputting keys in the FLU. Just cut and past keys into where directed and the program will convert which key on the remote to press.
Hopes this helps.
I've left the program open (not protected) so you can modify it in the future if need be.
application/zipUpload
MODIFIED FLU KEY CONVERSION TABLE.zip (5.3 k)
Username: Tech2k
What the hell is an ".unk" file?
It's not an Excel file, according to Excel anyhow.
Username: Moboneii
don't know why when you d/l it from this site the file name is changed to .unk.
just rename the .unk to .zip and all is well.
Username: Vyizder_zomenimor
Post Number: 53
I bought a 2700 remote off the 'bay' to solve the problem.
Username: Moboneii
Yea, but don't you still have to do the mental math to convert the numbers into what buttons to push.
With this conversion program you copy/paste the key code and it will give you what buttons to push i.e PAUSE AUDIO EPG LAST FAV SAT
You don't have to keep looking at the TV screen to figure out that A=pause, B=audio, C=epg...etc.
Username: Nydas
Post Number: 7813
mcb: Keep up the good work. Every little thing helps.
Change the file name to .zip and then unzip it. Then you can read th excel file
Username: Nydas
Post Number: 7814
application/mswordUpload
MODIFIED FLU KEY CONVERSION TABLE.doc (52.2 k)
Username: Moboneii
here's a .rar of the conversion.xls.
Let's see if this works better.
unknown/unknownUpload
MODIFIED_FLU_KEY_CONVERSION_TABLE-443236.rar (4.7 k)
Username: Moboneii
Nalin,
Any clue as to why this file d/l's as an unknown file .unk ?
Both the .zip and .rar comes down as .unk.
Username: Nydas
Post Number: 7822
Ecoustic does not like posting of files for download. They tolerate extended HTML documents and pictures via .doc and .jpg files, the way I posted for you. They call the others .unk (UNKnown)
Username: Dishlover
Toronto, Ontario Canad
Post Number: 119
Do we have to upload this file to receivers?
Username: Nydas
Post Number: 7828
These are information only files. You can view or download the .doc files. The .unk files are download first to you computer, then renamed and then viewed.
There is no loading to the receiver in either direction.
Username: Dishlover
Post Number: 120
Thanks Nalin. You are always candid and very helpful. Appreciated.
Username: Htran
All they keys on my fortec remote still screwed up. ex, left arrow = power, 3 is 2, 4 is 3. and there is no key for #2 so i cant input new keys. what do i do?
Username: Nydas
Post Number: 7835
Hoang: Just install CS_245T_lightning.
Username: Htran
Thanks Nalin. will try to install CS_245T_lighting. Currently using Fortec_remote245 bin
Username: Nydas
Post Number: 7836
CS_247T_Lightning with BEV fix (and DN) is now available at
[link removed]
http://public.box.net/2500_full_kit
