Conversion BINS 246
Username: Nydas
Post Number: 7806
jvvh_246 - Pansat and Fortec versions are avialable at
[link removed]
Username: Nydas
Post Number: 7807
I personally don't think jvvh_246 BINs are any better, but here is further URLs and converion kit.
They DO NOT address the BEV ECM
For Pansat 2500/FLU new conversions and converted to 2700
Use only on unconverted 2500/FLU or converted receivers.
DO NOT USE ON Genuine Pansat 2700 or on Pansat 2700 clones
Everything you need for 2500/Flu to 2700 conversion in one package.
Instructions included.
The latest CS_245T_Lightning files for DN and BEV fix.
The latest jvvh_244, 245 and 246 files for Pansat or Fortec remote.
The 245 and 246 version conversion files are available separately as well
Some jtag files are also included.
The full kit is in full_kit14D.zip. Unzip into a new jvvh directory. and read the instructions in the Instructions.doc file.
http://public.box.net/2500_full_kit
Download the kit and unzip in a new jvvh directory. Read the Instructions file. Or just download the 245 or 246 files.
Username: Roundtree
Post Number: 27
Can someone confim this,
I have tried Jvvh_PansatRemote_246 bin on my Pansat 2500 converted clone
but the zero key does not work under pansat mode or Fortec mode, with dual mode remote.
Converted back down to CS_245T_Lightning_100t_Series_serial and remote works fine.
Is there a CS_246T_Lightning bin?
Username: Nydas
Post Number: 7812
There is no CS-246T_Lightning, but there is a Lothario 246V2. A newcomer. His version 1 of 246 did not work well. There may be a saif version as well, but I am not sure.
You can find the file in the Pansat 2500 section of files in
[link removed]
Username: Ragi48
Flushing, New york Usa
Post Number: 27
Nalin is right. On a converted Pansat 2700, I have bin245 and is working very well. As Nalin says, I do not think 246 is any better.
Username: Roundtree
Post Number: 28
Thanks Nalin and Mike.
Username: Devenw
MISIS
Post Number: 58
B...75 Error on Panasat 2500 converted 27000
which file should i download first
Username: Luv2meet
Post Number: 34
guys, are you saying b3v is up now using the 245 or 246 ?
Username: Tibie11
Post Number: 28
is bev work in pansat 2500 to 2700?
Username: Kimo74
Post Number: 63
what is the point of the jvvh 246 if it will not fix the BV issue ?
Username: Nydas
Post Number: 7826
Sharuk
"B-75 error" It is not an error. It means you have successfully converted the boot from b60 boot to b75 boot.
I have answered you elsewhere.
