Which one?????
Username: Blaaaahhhhh
Warrior, Alabama Usa
Post Number: 38
im having a hard time with money but want a new amp bad, i found two amps for good prices, rf t5001bd or a kicker 06zx750.1 which one would be better???
Username: Drant19
DUB-C, TX
Post Number: 331
well whats the final impedance you need? because the RF is 1ohm stable and the Kicker is 2ohm.
Post Number: 40
well I'm bridging it to 2 4ohm dvc pioneers so I only need 2 ohms
Username: Somedonniedude
Illinois United States
Post Number: 868
You need a 1 ohm stable amp. What model pioneers do you have?
Post Number: 41
ts-w1207d4's
Username: Juliob
Santo DomingoDominican Re...
Post Number: 5159
rockford fosgate is a better choice, you're going to wire PARALLEL/PARALLEL ok?
Post Number: 42
Not really
Username: Nd4spd18
Northwest PA
Post Number: 5997
You can't wire those subs to 2 ohm.
You need to wire all coils in parallel for 1 ohm total. So get the RF amp.
