Gold Member Username: NydasPost Number: 7806 Registered: Jun-06 | jvvh_246 - Pansat and Fortec versions are avialable at [link removed] |
Gold Member Username: NydasPost Number: 7807 Registered: Jun-06 | I personally don't think jvvh_246 BINs are any better, but here is further URLs and converion kit. They DO NOT address the BEV ECM **-----**-----**-----**-----**-----**-----**-----**----- For Pansat 2500/FLU new conversions and converted to 2700 Use only on unconverted 2500/FLU or converted receivers. DO NOT USE ON Genuine Pansat 2700 or on Pansat 2700 clones Everything you need for 2500/Flu to 2700 conversion in one package. Instructions included. The latest CS_245T_Lightning files for DN and BEV fix. The latest jvvh_244, 245 and 246 files for Pansat or Fortec remote. The 245 and 246 version conversion files are available separately as well Some jtag files are also included. The full kit is in full_kit14D.zip. Unzip into a new jvvh directory. and read the instructions in the Instructions.doc file. http://public.box.net/2500_full_kit Download the kit and unzip in a new jvvh directory. Read the Instructions file. Or just download the 245 or 246 files. |
Bronze Member Username: RoundtreePost Number: 27 Registered: Jun-06 | Can someone confim this, I have tried Jvvh_PansatRemote_246 bin on my Pansat 2500 converted clone but the zero key does not work under pansat mode or Fortec mode, with dual mode remote. Converted back down to CS_245T_Lightning_100t_Series_serial and remote works fine. Is there a CS_246T_Lightning bin? |
Gold Member Username: NydasPost Number: 7812 Registered: Jun-06 | There is no CS-246T_Lightning, but there is a Lothario 246V2. A newcomer. His version 1 of 246 did not work well. There may be a saif version as well, but I am not sure. You can find the file in the Pansat 2500 section of files in [link removed] |
Bronze Member Username: Ragi48Flushing, New york Usa Post Number: 27 Registered: Jun-06 | Nalin is right. On a converted Pansat 2700, I have bin245 and is working very well. As Nalin says, I do not think 246 is any better. |
Bronze Member Username: RoundtreePost Number: 28 Registered: Jun-06 | Thanks Nalin and Mike. |
Bronze Member Username: DevenwMISIS Post Number: 58 Registered: May-06 | B...75 Error on Panasat 2500 converted 27000 which file should i download first |
Bronze Member Username: Luv2meetPost Number: 34 Registered: Dec-07 | guys, are you saying b3v is up now using the 245 or 246 ? |
Bronze Member Username: Tibie11Post Number: 28 Registered: Sep-07 | is bev work in pansat 2500 to 2700? |
Bronze Member Username: Kimo74Post Number: 63 Registered: Jan-07 | what is the point of the jvvh 246 if it will not fix the BV issue ? |
Gold Member Username: NydasPost Number: 7826 Registered: Jun-06 | Sharuk "B-75 error" It is not an error. It means you have successfully converted the boot from b60 boot to b75 boot. I have answered you elsewhere. |
