Username: Imars99 BRAMPTON,
ONT
CANADA
Post Number: 48 Registered: Aug-06
Sunday, February 03, 2008 - 11:17 GMT Viewsat realease Bev fix.
Username: Shittabattie Post Number: 5 Registered: Jan-08
Sunday, February 03, 2008 - 12:45 GMT Where is it posted?
Username: Metallica Post Number: 13 Registered: Jan-08
Sunday, February 03, 2008 - 13:43 GMT shitta look in there. http://www.ftabins.net/forumdisplay.php?f=35
Username: Qupaga Post Number: 15 Registered: Dec-07
Sunday, February 03, 2008 - 13:55 GMT PFTAUSW-080203U BEV Freezing Fix on f2atv, VS ULTRA working fine according to some opinions
Username: Shadycove Post Number: 150 Registered: Sep-06
Sunday, February 03, 2008 - 13:56 GMT i just loaded the latest ultra file from fta bins and my machine seems to be not coming bach on...there are 4 dashes across the front of it buts thats all....nothin....now what?
Username: Metallica Post Number: 14 Registered: Jan-08
Sunday, February 03, 2008 - 14:04 GMT BetterOffRed try to reload the new bin again.. but still don't work then load the factory bin then the new bin..you are having niterider when you see the 4 dashes moving like that..your box still alive..
Username: Plymouth Quebec city,
Quebec
Post Number: 31 Registered: Jan-08
Sunday, February 03, 2008 - 14:41 GMT Remember make a hard boot before load new bin for release internal memory (switch on back)
Username: Shadycove Post Number: 151 Registered: Sep-06
Sunday, February 03, 2008 - 14:50 GMT the dashes arnt't moving...i tryed to load the factory bin using the cable but no luck
Username: Scott21 Post Number: 18 Registered: Sep-07
Sunday, February 03, 2008 - 15:47 GMT you need to a flash fail fix . you can find it at ftatalk . I havee used it and it works good. you will have to load it will your null cable.give it a try.
Username: Shadycove Post Number: 152 Registered: Sep-06
Sunday, February 03, 2008 - 16:38 GMT thank you very much...the flash fail worked....thanx
Username: Shittabattie Post Number: 6 Registered: Jan-08
Sunday, February 03, 2008 - 16:47 GMT where do i find the flash fail fix?
Username: Bill038 Post Number: 461 Registered: Sep-06
Sunday, February 03, 2008 - 16:55 GMT Read two posts up from yours, he told you where it was.
Username: Kingofdakingz Post Number: 153 Registered: Jun-06
Sunday, February 03, 2008 - 17:37 GMT working good here
Username: Blueash Post Number: 47 Registered: Jul-07
Sunday, February 03, 2008 - 17:38 GMT just cant upload th file...
Username: Tekila2006 Post Number: 42 Registered: Aug-07
Sunday, February 03, 2008 - 22:05 GMT I think it is just going down again. 4h53pm
Username: Loola Canada
Post Number: 19 Registered: Dec-07
Sunday, February 03, 2008 - 22:07 GMT Bev down on Viewsat Plat...Aaaarrrrgghhh!!
Username: Farmer_cross Post Number: 1 Registered: Feb-08
Monday, February 04, 2008 - 00:34 GMT what is the fix for bev feb 3??
Username: Hshakarchi Post Number: 203 Registered: May-06
Monday, February 04, 2008 - 06:52 GMT new fixes are out PFTAUSW-080204U at ftaforall*net
Username: Ather_da_don Mississauaga,
Ontario
Post Number: 351 Registered: Oct-07
Monday, February 04, 2008 - 12:25 GMT Also released at www.dishkeyz.blogspot .com (remove the space)
Username: Starstruck Mississauga,
ON
Post Number: 66 Registered: Dec-07
Monday, February 04, 2008 - 12:26 GMT The latest files for bev fix are out at www.ftafixer.blogspot.com as well!!
Username: Leafs Post Number: 444 Registered: Oct-07
Monday, February 04, 2008 - 14:02 GMT latest pansat and viewsat files are now posted at www.ftasolutions.co.nr
Username: Nydas Post Number: 7842 Registered: Jun-06
Monday, February 04, 2008 - 16:57 GMT Viewsat BEV fix available at: [link removed] [link removed]
Username: Cubiche CUBA,
CUBA
Post Number: 75 Registered: Jan-08
Monday, February 04, 2008 - 17:20 GMT FIXES AVAILABLE AT WWW.CRAZYFTA .COM
