Username: Dude123 Www. CrazyFTA .com
Post Number: 1996 Registered: Jul-06
Monday, February 04, 2008 - 08:17 GMT All pansat and viewsat files availaible at www.crazyfta.c *om(remove*). Others will be posted as soon as they come out...ENJOY
Post Number: 1997 Registered: Jul-06
Monday, February 04, 2008 - 08:46 GMT CaptiveWork Fixes are posted at www.crazyfta.c *om(remove*) as well!!!!
Username: Hardwarecrazy Post Number: 16 Registered: Dec-07
Monday, February 04, 2008 - 12:05 GMT Captive works file for CW700 is old (CW700SV1.48_2008_02_02) and does not work. Need an update.
Username: Hardwarecrazy Post Number: 18 Registered: Dec-07
Monday, February 04, 2008 - 12:19 GMT I should qualify my above post as works only for DN and not for b3v.
Username: Ather_da_don Mississauaga,
Ontario
Post Number: 350 Registered: Oct-07
Monday, February 04, 2008 - 12:24 GMT They are also at www.dishkeyz.blogspot .com (remove the space)
Username: One_eye_jack Post Number: 332 Registered: Nov-07
Monday, February 04, 2008 - 13:39 GMT Before you go to the above listed sites for files ask yourself this question. why can you go directly to http://ftabins.net/ from here but not from the ones listed above? FTABins.NET :: The Greatest FTA Community on the NET! Total Members:122,652
Username: Leafs Post Number: 443 Registered: Oct-07
Monday, February 04, 2008 - 14:01 GMT latest pansat and viewsat files are now posted at www.ftasolutions.co.nr
Username: Tibie11 Post Number: 29 Registered: Sep-07
Monday, February 04, 2008 - 14:19 GMT files for pansat 2500 to 2700?
Username: Cubiche CUBA,
CUBA
Post Number: 71 Registered: Jan-08
Monday, February 04, 2008 - 15:31 GMT YUKON ARE YOU PRFRMNJ
Username: Nydas Post Number: 7841 Registered: Jun-06
Monday, February 04, 2008 - 16:54 GMT CaptiveWorks - new files for BEV fix Viewsat and Pansat - new files for BEV fix 2500/FLU to 2700 conversion files: [link removed] - ALL [link removed] - ALL genuine Viewsat.
CUBA
Post Number: 76 Registered: Jan-08
Monday, February 04, 2008 - 17:21 GMT ALSO AVAILABLE AT CRAZYFTA
