all u need is to find the one wire in the back of the hu wich is the power antenna and you need a part to convet wires to rca output thats about it just run power and ground
is there a way to do it without the converter or is that it and i dont even know how to get to the wires from the factory hu maybe i shou,d get a professional
no you dont need a pro and you do need the converter just tap into you rear speakers in the back dash and as for the power ant just use a check light for that
your remote wire is not a all time hot its what kicks ur amp on and off and the +12 is a all time hot wire... G- is your ground... u can tap into the fuse box and find a fuse that has +12 when u turn the ignition on... and yeah just tap into the rear sneakers. it wont sound the best that way... it will distort. if u had a converter than what it does it lower the watts coming out from the speakers. so that it will be right watts u can pick thim up at any wal-mart for 4 $16 great to have..
