FLU 2500-2700 CS245t file is out
Username: Cricpower
Post Number: 47
Just tested and it's working for DN and BEV:-)
found it at ftabins
Username: Nydas
Post Number: 7699
For Pansat 2500/FLU new conversions and converted to 2700
Use only on unconverted or converted 2500/FLU receivers.
DO NOT USE ON Genuine Pansat 2700 or on Pansat 2700 clones
Everything you need for 2500/Flu to 2700 conversion in one package.
Instructions included.
The latest CS_245T_Lightning files for DN and BEV fix.
The latest jvvh_244 files for Pansat or Fortec remote '" for DN and BEV fix.
The 244 and 245 version conversion files are available separately as well
Some jtag files are also included.
The full kit is in full_kit14B.zip. Unzip into a new jvvh directory. and read the instructions in the Instructions.doc file.
http://public.box.net/2500_full_kit
Download the kit and unzip in a new jvvh directory. Read the Instructions file. Or just download the 245 or 244 files.
Username: Kimo74
Post Number: 60
thanks nalin you are the best
Username: Viruscauser
Leesburg, Georgia
Post Number: 756
Nalin, just curious, what's the difference between the 244 and the 245 bins?
I watch DN for which the 244 works just great. I never fix something that ain't broke but I'd like to know the difference.
Username: Hades305
Post Number: 27
245t works for both dn and bev, but was intended for bev after the last ecm(around 8 pm last night)
Leesburg, Georgia
Post Number: 757
Thanks Hades305. That confirms that those with only DN don't really need to upgrade if they don't want to. Appreciate it.
Username: Desi_munda
Post Number: 67
how to get the pakistani channel AAG and Super Geo on DN.
I have Flu to pansat converted.
Username: Alime_123
Afgh, Ghazni Afgh
Post Number: 72
Hi all
Is Hotbird Satellite On Ariza 700?
how can i get Hotbird Satellite with Ariza700?
can some one help plaese?
thanks alot
Username: Ragi48
Flushing, New york Usa
Post Number: 23
This morning I loaded jwh_244 for my converted Pansat and is working fine. Nalin Nyda posted the bin file at www.publicbox.net. Thanks again Nalin.
Username: Ragi48
Post Number: 24
Sorry it should be www.publicbox.net/2500 full kit.
Username: Ragi48
Post Number: 25
Sorry again and it should be www.public.box.net/2500 full kit.
Username: Ntns
Currently I have bin 244 for FLU/converted 2700 but I don't have any PPV. Will this 245 fix problem?
Username: Cover_point
Gone. When is the 246 going to be available?
Username: Leo_here
Post Number: 45
All Internationals, PPV and P0Rn wide openw ith CS245T for FLU/converted 2700 !
Just power scan both dishes after loading the bin.
New channels AAG and GEO news are up as well!!
Post Number: 7
Leo, are sure about this? I downloaded the 245 BIN and it was working for about 1 hour and then went down.
Username: Cartier1
Post Number: 1709
if u guys read you dont need an other bin. you need to do your homework
and next bin will in home depot tonight.
Username: Ntns
I downloaded the 245 and it is working only for regular cheanels but not for PPV. PPV is frezing and shoving no signal. Is enyone else have same problem?
Username: Nydas
Post Number: 7707
jvvh_244 was working very well for DN
CS_245T_lightning is working very well for DN.
All Internationals, PPV and P0RN are up.
Username: Jaye50
Post Number: 66
using a converted flu..... i loaded the jwh fortecremote 244 bin and my remote would not work.....i then loaded the jwh pansatremote 244 bin and my remote now works except for the "0" button but my "last" button seems to be giving me "0"....so.....guess i'll leave well enough alone till the next ecm
Username: Nydas
Post Number: 7712
jaye: Use CS_245T_lightning. In spite of the two types of BINs some people are still getting problems with the remotes on jvvh BINs.
Username: Koko_wawa
Post Number: 205
New ECM in the stream. Black TV screen sooooooon
Username: Jaye50
Post Number: 67
nalin.....will do....thanx
Username: Kimo74
Post Number: 61
hey every one
did we lose BEV now ???
Username: Snissar
Post Number: 63
BEV
Username: Hamid9272
Post Number: 40
BEV JUST WENT DOWN.
Username: Kimo74
Post Number: 62
hey nalin
is their any fix for the BEV or not yet.
