Gold Member Username: Skibum12189Cleveland Post Number: 2541 Registered: Mar-06 | Alright some of these ideas might be dumb...if they are please tell me haha Alright first of all, would a colored port be cool? like a silver or a blue or something? maybe a dark navy? Also, if I got silver or blue, could I put a neon inside the box near the end of the port closer to the sub (hidden from view looking in th port/not interfering with the air movement - or does any thing inside the box interfere with air movement? or would that neon get flucked up/sub/idk? i know neon is gey most of the time, but this is just me being bored and thinking. thanks |
Gold Member Username: Skibum12189Cleveland Post Number: 2542 Registered: Mar-06 | no one? |
Platinum Member Username: BestmankindRD 1000.1D with SI MAG... Post Number: 17652 Registered: Oct-05 | keep it simple. |
Gold Member Username: MgbcsLincoln, Nebraska Post Number: 2131 Registered: Dec-06 | aka black |
Gold Member Username: MixmastaspigCanada, Canada Canada Post Number: 1464 Registered: Sep-05 | Get some fur and make it look like a cr0tch, that would be awesome! I think I am going to make my new box white... |
Gold Member Username: JtownTeam Revolution, Texas Post Number: 1889 Registered: Mar-07 | kinda on topic, sorry to thread jack, but does painting your Basket have any negative effects? strictly the basket and nothing else. |
Gold Member Username: The_image_dynamicSan Diego Post Number: 3403 Registered: Dec-06 | Well some of those neons can survive underneath a car with all the jars and bumps that are involved there so one of those would survive inside a sub but those computer ones would fail for sure. You don't want anything in your port anyways to avoid any sort of turbulence (and resulting noises) it can create. As far as painting just the basket... won't affect anything at all. |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 12935 Registered: Jun-06 | Cal, I have neon in my box and it hasn't failed me yet. Not a flutter or dimming. It's not an SPL box either but........ |
Platinum Member Username: Rovin4 10 Pioneer... Post Number: 12963 Registered: Jul-05 | hows bout a SILVER port ... |
Gold Member Username: ShortysetniesRock Vegas, NC US Post Number: 1864 Registered: Mar-06 | "keep it simple" ^Coming from the man that changes systems more than he changes underwear... I think a silver or blue port would be cool. If you did a dark blue port it would look black about 3" in the box though. Dont do a neon, do an LED strip from www.oznium.com Look at the flexible LED strip. VERY bright. But yeah, I say go for it. |
