Mmats vs. kicker which set up?...
Username: Killer44
Ontario Canada
Post Number: 974
so my brothers got a ext cab s10 and i got two possible set ups to throw in there for him, one thing to keep in mind is that he doesnt want to loose the back fold down seats, so its gunna have to be a normal sized sealed or a smaller ported as not to take up too much room, well heres the amp hes got
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2961
and heres the first sub (its the one on the top of page, 250rms MMATS SERIES 12")
http://www.lightav.com/car/mmats/subwoofers.html
and secondly i got three 10" cvrs for him to choose from (two old models and one new) but hes only gunna use one.
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2448
both subs are dvc 4ohm so i know there gunna work with the amp...
last question is that the infinity amp doesnt have a sub sonic filter, and ive never ran a ported box with one, so if i did go ported with either set up, how would i do it?
Username: Zacdavis
Beloit, Wi
Post Number: 1545
If the back seats are folded down, then where will your feet go if theres a box there?
He should run a small box off to one side and just forget about using one of the seats.
Username: Killer44
Ontario Canada
Post Number: 975
well yeah we are considering that as one of our plans and possibly putting some cushion on the box so it could be used as a seat if needed....
Username: Killer44
Ontario Canada
Post Number: 976
bump...anyone?
Username: Kingtutus
Lincoln, Nebraska U.s.a
Post Number: 142
go with the mmats
Username: Killer44
Ontario Canada
Post Number: 977
ok anyone other opinions and if i go mmats should i jsut stay sealed b/c the infinity does not have a ssf...?
