Speakers for minimal cost
Username: Roby1227
I was looking for the cheapest set of loud speakers I can find to provide background music for poolparties and possibly other get togethers like this.
Sound quality is not all that important.
I was looking at some Gemini GSM-3200 speakers to do the job. I know their quality is probably poor but I can not seem to find anything comparable in size for the price. Any suggestions?
Username: Scorpio1
Philadelphia, PA USA
Post Number: 64
Check this out
http://www.circuitcity.com/ssm/MTX-ThunderPro2-Speaker-TP1200/sem/rpsm/oid/17940 5/rpem/ccd/productDetail.do
Username: Nickelbut10
Post Number: 1110
How much are the Gemini's? What stores do you have access to? Do they need to be small, large?
Username: Jan_b_vigne
Dallas, TX
Post Number: 12228
If sound quality is not all that important, why bother to shop? Buy the cheapest you can find.
Post Number: 1112
lol true. Insignia bookshelves from Best Buy or something.
Username: Stu_pitt
Irvington, New York USA
Post Number: 2445
He's probably going to need something a little bigger than the Insignias for pool parties.
Do you have a local Guitar Center or another similar store in your area? That's where I'd start.
Username: Stu_pitt
Post Number: 2446
I just noticed the name Bob Sagget. Classic.
I'm reminded of his famous "Mari juana is not a drug" line from Half Baked.
Username: Mvanmeter
KY USA
Post Number: 136
decent speakers, even at the low price
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=310-069
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 627
What about your local pawnshops? The ones around me always have big, loud, bad-assed speakers.
Dallas, TX
Post Number: 12243
Bad-assed? Or half-assed?
Username: Dmitchell
Post Number: 631
Emphasis on "bad".
Username: Roby1227
The Geminis are Dual 15 3 way speakers...
They are passive speakers, but I do not need the flexibility of active speakers. I can get a pair of these for about $460 I can not find any speakers comparable for the size and price.
And for speed and Decibels it seems to usually follow a similar rule: There is no replacement for displacement.
The only reason I ask the question about the Geminis is I don't want to buy them and have them making clapping noises or whistling because the box was not engineered right or the drivers are poorly vented.
A pic is worth 1000 posts!!
Post Number: 13243
I think you'll be fine. How many pool parties have been ruined by ppl commenting on the SQ of the set? How many parties do you host in a year? 15s will probably disturb some neighbors. Have any lol? Invite them then.
