Platinum Member Username: BestmankindRD 1000.1D with SI MAG... Post Number: 17553 Registered: Oct-05 | if you guys read the question at the bottom, this is what some dude asked these guys that are selling the sub. its a adire brahma. anyways here is the question and answer. Q: So you are saying my amp will give me the same power at 2 ohms, that it will give me at 1 ohm? Please explain? Jan-26-08 A: The rated output is based on a fixed input, say 1v. If you double the input, you'll double the output as long as you haven't gone below the recommended impedance are already driving the power supply into saturation. So if you're loaded at 2ohms and you double your input, you'll double the output.. You can get this though by simply making your amp more sensitive to the original input.. adjusting the gain. Especially class D amps, they have a very wide parabola of power vs impedance curve. You can test this by simply using a DVM to measure the output on say a 1ohm load. Then disconnect one voice coil so you're running a 2ohm load and adjust the gain until you get the same voltage reading. Presto, the woofer moves the same as it did when it was at 1ohm... because it's getting the same power. Amplifiers should really be rated in db, the amount of gain they give to the signal before clipping... not power. http://cgi.ebay.com/NEW-ADIRE-AUDIO-BRAHMA-MkIV-15-D2-w-FREE-SHIPPING_W0QQitemZ2 20194269208QQihZ012QQcategoryZ18804QQrdZ1QQssPageNameZWD1VQQtrksidZp1638.m118.l1 247QQcmdZViewItem |
Gold Member Username: Extrmndor3Http://illuzonemu.serv..., ^^^Sick Game Post Number: 7630 Registered: Feb-06 | CHAD WE NEED TO TALK !!!!!!!!!! |
Silver Member Username: Stateprop486PA Post Number: 199 Registered: Jan-08 | chauncey bought the same sub from them too, but used i think. |
Platinum Member Username: BestmankindRD 1000.1D with SI MAG... Post Number: 17555 Registered: Oct-05 | about what? |
Silver Member Username: Nickyp0219Post Number: 423 Registered: Jun-06 | lol yea that doesnt make much sense to me |
Platinum Member Username: BestmankindRD 1000.1D with SI MAG... Post Number: 17556 Registered: Oct-05 | yeah. they are basically saying turn the gain up to compensate. |
Gold Member Username: Extrmndor3Http://illuzonemu.serv..., ^^^Sick Game Post Number: 7631 Registered: Feb-06 | just kidding |
Platinum Member Username: BestmankindRD 1000.1D with SI MAG... Post Number: 17557 Registered: Oct-05 | you're in a good mood today man. lol. |
Gold Member Username: Extrmndor3Http://illuzonemu.serv..., ^^^Sick Game Post Number: 7632 Registered: Feb-06 | yes i am but seriously chad u been on some shyt and we need to talk |
Platinum Member Username: BestmankindRD 1000.1D with SI MAG... Post Number: 17559 Registered: Oct-05 | i've been on what sh!t? lol. |
Gold Member Username: Extrmndor3Http://illuzonemu.serv..., ^^^Sick Game Post Number: 7633 Registered: Feb-06 | just kidding.... |
Gold Member Username: FrkkevinResonant Engineering..., Fort Worth... Email Post Number: 4438 Registered: Nov-05 | itll put out the same power, just not clean power this is the diff between clean rms power vs dirty peak power |
Silver Member Username: Wolf_houndPhoenix, AZ Post Number: 546 Registered: Sep-05 | I bought my diamond audio 1200.1 from them for 180 here locally he said the amp would produce full power at 4,2 and 1 ohm. My friend also bought a diamond audio d6 600.1 he said the same thing. I told him i looked it up and it only does around 350 at 4ohms, he was like ya we are trying to stop companies from saying that.I just laughed. And i don't think those are "real" bramhas a while ago they were selling those with their own "Custom" coils and calling them brahmas Just cause everything else was the same basket,motor ect... So i dont know if i would trust them. |
Platinum Member Username: BestmankindRD 1000.1D with SI MAG... Post Number: 17565 Registered: Oct-05 | yeah that is just straight out bullsh!t those guys are telling. |
Silver Member Username: Stateprop486PA Post Number: 201 Registered: Jan-08 | lol, chad i installed my 7" indash today, and i love it, the bass sounds so much louder for sum reason and hits way better. im really satisfied. |
Platinum Member Username: BestmankindRD 1000.1D with SI MAG... Post Number: 17567 Registered: Oct-05 | nice. see you didn't need to worry about all that preout voltage crap. lol. |
Silver Member Username: Stateprop486PA Post Number: 202 Registered: Jan-08 | yea bro, i was suprised..so was my boy...songs that didnt even hit as good on the pioneer, hit very well, i guess must be the graphic band equalizer. i didnt kno what i was doing and sumhow made it sound good. lmao |
Platinum Member Username: BestmankindRD 1000.1D with SI MAG... Post Number: 17568 Registered: Oct-05 | lol not knowing what i was doing but sumhow made it sound good FTMFW!!! why don't you email the seller and tell him you like it. lol. |
