Proper sub wiring
Username: Pbplayer05
Carroll, Iowa
Post Number: 306
well when i got my subs there dual 4ohm i was told to wire the positives on each sub together and then the negative but was not told to wire the subs together and when ive tried doing it it seems like there aint enough room to put all the wire in it so how do you go about doing it also does it matter if you use smaller speaker wire to wire them together then the bigger stuff to wire them to the amp
RD 1000.1D with SI MAG...
Post Number: 17482
this is the way i do it so i don't have to cram 2 cables one terminal.
A pic is worth 1000 posts!!
Post Number: 12835
It should all be the same gage wire.
Carroll, Iowa
Post Number: 309
is that taped together or wat?
ok thats what i was thinking it just aint enough room for that much wire ill have to try what chad does
Carroll, Iowa
Post Number: 311
ya thats what i was thinking but it dont fit at all so ill have to try chads way
Username: Waresgaragestereo
Fort Valley, GA United States
Post Number: 82
all speaker wire should be the same guage.
Post Number: 17505
yeah i taped mine together at the junction.
Carroll, Iowa
Post Number: 317
what would this be
Carroll, Iowa
Post Number: 318
also how well does the tape hold
Post Number: 17509
well i first used that tube which you crimp. the i put the tape over it.
Carroll, Iowa
Post Number: 319
would my picture be 2 ohms then?
what tube?
Post Number: 17512
its a little plastic tube which you use to connect 2 cables together and you crimp it.
you can't wire 2 dvc 4ohm subs to get 2ohms. you can either get 1 or 4ohms.
are your subs dual 4ohm subs? also what are you trying to achieve?
Carroll, Iowa
Post Number: 320
well thats what i was wandering they are wired like the picture is and the subs arnt wired together thats how i was told to get a 1ohm load so would that be right?
were do u get one that u can connect three wires and fit 12 gauge wire
Post Number: 17515
i am getting confused here. sorry justin. be more specific.
what subs do you have?
how many subs do you have?
are they dual 4ohms or dual 3ohms?
what ohm is your amp stable at?
answer those questions and i will try to draw a better diagram for you. now i am done from my work so it will take me like an hour to get home so i won't be able to reply. but i am sure someone will.
Username: Ska
Post Number: 230
i think that might be a 4 or 8 ohm load to answer the question
Carroll, Iowa
Post Number: 321
well i have 2 dual 4ohm si bms that were hooked up to a sae 1000d(will now be a us amps md2d)which is 1ohm stable and i was told that the way the subs above were wired at 1 ohm but i dont think they are i was think i had them each wired at 2 ohms going into the amp but i may be mistaken?
also were would i get those tube things to wire three wire ends together i am using 12 gauge wire
Post Number: 17516
since the sae 1000 has 2 + and 2 -, you can just connect your positive and negative of each sub in to each one. so if you wire your subs to 2ohms each going in to the each set of terminals on the amp, it will be a 1ohm load cause its parallel inside the amp.
Carroll, Iowa
Post Number: 325
thanks
so what about them tube things
