82W please help
Username: Smartboyveer247
I am new to all of this and can someone please help me find 82W, what do I need to do. thanks I have a pansat 2700a
Username: Kirankumar
Kenya
Post Number: 1134
is your dish aligned to 82W ?
no its aligned to 61W
Kenya
Post Number: 1135
you need to align your dish to 82w first.
go to www.dishpointer.com
Kenya
Post Number: 1136
let me know if you need any more help
What is this? what do I need?
Dish Setup Data
Elevation:38.5°
Azimuth (true): 196.5°
Azimuth (magn.): 212.3°
LNB skew: 11.9°
Kenya
Post Number: 1137
your dish needs to be adjusted to those settings so the dish would point at 82w satellite.
if you are not good with this kind of stuff you might need an installer come and move the dish for you
ya but I live in USA,so those are the angles that i need to move the dish?
Kenya
Post Number: 1138
yes.
tell me why want 82 w
also when you move your dish you will lose 61.5 which carries international channels,is that what you want?
i have 2 sat dishes
Kenya
Post Number: 1139
so i guess you have 61.5 on one dish and 119 and 110 on the second dish right
Post Number: 7
no my friend just moved and he gave me his dish, i have one pointed to 61.5 and i want the other pointed to 82W
Kenya
Post Number: 1140
that is good,
you will need to install that second dish as per dishpointer instructions,then you will need a switch,so you will have 2 cables coming from 2 sats to switch and 1 cable from switch to receiver
Kenya
Post Number: 1141
you will need a DisEqC switch
Post Number: 9
ya i already have a switch i think its called a diseqc switch, this is what that site gave me Elevation:38.5°
LNB skew: 11.9°
what so i do with it? how do i know which way to turn the dish?
Kenya
Post Number: 1142
do you have a signal meter?
Post Number: 11
no
Kenya
Post Number: 1143
ok
first you need to install your pole,this should be plumb (straight up)then on the dish adjust your elevation,there are markers there.then you will have to guess ,you should get 82 w if you point it to the right of your 61.5 and keep on moving it slowly until you lock in.it will take a lot of time
Post Number: 12
see i got 61W easily by using the dishnet receiver,you go to dish pointer and when you pick up the angle the thing goes green and when you dont have the angle the thing goes red, is there anything like that on a FTA receiver?
Kenya
Post Number: 1144
exactly,
you got it,and make sure you see 82w on the top right hand corner
Post Number: 13
no i am asking it there sometihng like that on the pansat or nfusion?
Kenya
Post Number: 1145
it is on all fta receivers yes
Post Number: 14
ok thanks a lot man, what receivers do you have?
Kenya
Post Number: 1146
i have c00lsat 5000 6000 7000,
if you follow my instructions you will be ok,if you have any more problems,i am at www.crazyfta
i can help you there.good luck
Username: Dimwitt
Post Number: 385
use the quality meter in the antenna setup, for locking onto a sat.
install dish and diseqc switch , do antenna settings for 82 with proper diseqc port and lnb type selected.
use dishpointer.com , setup the google map for your dish location , aim as shown and adjust elevation till you get good quality
Post Number: 15
ok thanks a lot tooter and african
Username: Madflea168
Post Number: 153
African,
I have a dtv 3 lnb sitting on my roof, do you know if the lnb would work on bev?
Username: Warbe
you can use your old dish recevier to find the signal from a bev sat(82 or 91)
