Bronze Member Username: Jonny_b
Kellogg,
Idaho
U.S.
Post Number: 26 Registered: Oct-07
Posted on Im probably going to buy this compnent set, anyone have these and are they any good? give me your review of them |
Bronze Member Username: Exige
Post Number: 92 Registered: Nov-07
Posted on just say no. whats your budget and what type of sound do you like. using an amp or just head unit? |
Kellogg,
Idaho
U.S.
Post Number: 27 Registered: Oct-07
Posted on Whats wrong with them? My budget is 250.00-275.00 for a H.U. and a set of speakers for upfront. i have an amp i can run them off of if need be. |
Gold Member Username: Bnd_rulez
Phoenix,
AZ
Post Number: 1318 Registered: Mar-05
Posted on Well, they are Audiobahn. Audiobahn is grade A flashy junk. Over rated and their build quality is more than suspect. What does the amp do RMS? Do you have the name and model number of the amp? |
Gold Member Username: Adddisorder
Palm Beach,
Florida
Post Number: 5842 Registered: Jan-06
Posted on they suck. |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 5881 Registered: Jul-06
Posted on audioburn = crap |
Post Number: 94 Registered: Nov-07
Posted on let us know about the amp...an amp will sound better than any HU will. |
