110.0, 118.7/119.0, 148.0
Username: Lolol
Post Number: 245
What is the easiest way to get all those? How many dishes? How many Lnbs do I need?
What kind of dish would be good for these sats?
what is this dish pro 1000 or whatever its called? whats the benifit of those?
Only serious answers please! I cant seem to find information that I am looking for, I have searched and read enough.
Thanks in advance!
Regards.
Username: Saqeeb9000
Post Number: 1839
i think best would be using a motor dish..
as we are seeing more and more channels are moving from one location to another... so motor dish would be best way to go..
Username: Kirankumar
Kenya
Post Number: 1150
you can get 110.119 and 118.7 on one dish which must be at least 30" and 2 lnbs 1 for 110 and the other for 119 and 118.7 ( this is a special lnb about $20)
you will need a second regular dish for 148 with single lnb
Post Number: 1840
my setup is this .. i have
148 dish (1 dish)
2nd dish has 2 lnb (82,91)
3rd one has 119 dish...
u can just have 2 dishes
1 30" dish 2 lnb (use circ lnb this way you will get 110,118,119)
2nd dish move to 61.5 is better option that 148...
Username: Solex98
Northwest, WA United States
Post Number: 9
The easiest, most practical and esthetic benefic way would be to go with a Toroidal 90 and the required LNBs (C/Ku band). I have it and I'm super happy with 91, 97, 110 & 119. I'm looking to add 118.7 and wonder if I can stretch it for 148 (They say you have a 40 degree span for birds but I heard of others stretching 50 degree +. I tried the thing with the motor, but it's totally unreliable, hard to setup and the wait time going through channels on different birds is forever. My 2 cents.
Username: Lolol
Post Number: 246
Thank you very much everyone for the input. It helped alot.
Thanks again
Regards....
Username: Wizzard2004
i went to the store to get a dual lnb but the guy said its only if u have more than 1 receiver, its to connect 2 receivers to one satellite he said it wont help in getting more channels, is tht right? right now i have 121 and i m not getting all the channels
Post Number: 9
so should i get teh dual lnb to get more channels or is it just to connect to 2 receivers?
Username: Vittu
Post Number: 127
Dual will get you 2 output to connect 2 receivers not more channels. Think of a longterm and get dual.
Post Number: 10
so wht should i do to get more channels?
Username: Solex98
Post Number: 10
"Dual will get you 2 output to connect 2 receivers not more channels. Think of a longterm and get dual."
Vittu, I tend to (partially) disagree with you; A dual LNB can get you more channels: A Circular Standard Dual output LNBF with Dual polarization can get you Echostar 7 (Dishnetwork 119°W) and Anik-F3 (at 118.8°W) in addition to hook up 2 receivers, therefore: more channels.
Username: Nydas
Post Number: 7723
Dual LNB = 1 sat and two receivers
Twin LNB = 2 sats and one receiver (often used with 110/119W or 82/91W)
Dual twin = 2 sats and 2 receivers.
"Dual output LNBF with Dual polarization" Universal LNB is specific version of a dual twin designed for 118.7W and 119W
Username: One_eye_jack
Post Number: 291
lolol
You can get all the Birds in the Arch with this setup.
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 28
A Fortec dish 30" 33" 36" with hh-90 motor and INVACOM universal LNB QPH031. Good for Echostar 3,6,7,8,9,10(1,2 in mid and coast west), Nimiq 1,2,3, AMC 3,4 , Intelsat 5,7,8. This is the best for have max channels, but you may listen 2 receiver on the same satellite only. I have a second dish 20 inch with motor and circular LNB for my wife.
Username: Plymouth
Post Number: 29
Yukon this is you on photo
Username: Madflea168
Post Number: 159
sweet, where did you find that pic.
