Username: Vittu Post Number: 133 Registered: Oct-07
Monday, January 28, 2008 - 23:34 GMT I just got a pansat 2700a original. What file will work and can I still use the same loader to load files to converted FLU. Thanks Last file loaded on the receiver is 75-2.33_EUbX Boot ver 75 25th Dec 2007
Username: Nydas Post Number: 7735 Registered: Jun-06
Tuesday, January 29, 2008 - 05:32 GMT Pansat 2700 - original. Use BL bins and 27.02 loader. Converted receivers use Blacklist 1.4 loader and CS_ or jvvH_ bins. If you confuse between these two you may kill you receiver. I have posted this information about 20 times in the last 2 weeks. Cable for Pansat 2700 is a null cable. Cable for converted receivers is straight cable.
Username: Vittu Post Number: 136 Registered: Oct-07
Wednesday, January 30, 2008 - 00:28 GMT Thanks Nalin. Got it all right. Just wanted to be sure since it's my 1st Pansat receiver
