Bronze Member Username: Gula187Baton Rouge, Louisiana USA Post Number: 96 Registered: Mar-07 | hey guys im just getting back into the audio world and i need help deciding on a new setup for my car.. 4 12's or 2 15's both ported with a $2200 budget for amps and subs [IMG]http://i150.photobucket.com/albums/s113/supaflybigdog/post-9626-1126217789.jpg[/IMG] |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 13669 Registered: Jul-05 | how big is the trunk??? |
Bronze Member Username: Gula187Baton Rouge, Louisiana USA Post Number: 97 Registered: Mar-07 | idk yet i will have to measure it |
Silver Member Username: Stateprop486PA Post Number: 170 Registered: Jan-08 | if thats ur car, its pimpin bro. |
Bronze Member Username: Gula187Baton Rouge, Louisiana USA Post Number: 98 Registered: Mar-07 | yea i just bought it off ebay |
Gold Member Username: Skibum12189Cleveland Post Number: 2530 Registered: Mar-06 | check all the engine compartments for sand. if you find ANY, do NOT buy the car. i see you're from LA and soon after Katrina and nowadays, car analysts or whatever say alot of the cars on ebay/cars.com/autotrader are flood salvages. |
Silver Member Username: Stateprop486PA Post Number: 174 Registered: Jan-08 | lol too late he alreadi bought it he said... |
Bronze Member Username: Gula187Baton Rouge, Louisiana USA Post Number: 99 Registered: Mar-07 | the car is fine. its getting repainted now |
