New member Username: JohnskonOhsweken, Ont. Canada Post Number: 1 Registered: Jan-08 | hi i,m really new i have ultra vs2000,just got bac fr. fta shop to get pic. bac, can some body teach me how to get a file or keys fr.the computer to the re ceiver? my receiver is autorolling but i get a pic. on my other receiver, i really don,t know wat i,m do,n so i need step by step instructions i have a wire that goe,s in bac off receiver to computer, i not sure wat keys or bin numbers are or how to get this f####k,n thing to work plzzz help |
Gold Member Username: Saqeeb9000Post Number: 1841 Registered: Oct-07 | here this is for viewsat that might help With new Bin's being released so often so many of you are losing channels during the updating process.. To save alot of time I thought I would post a few suggestions of what you should do before or during the updating process every time you upload a new bin in your receiver. I do this each time and never have any data loss I just do it this way, in this order, and watch tv seconds after putting the new bin in my receiver not after fighting my receiver for hours or day's. Upload #1 BEFORE you disconnect your receiver from the TV make a note of ALL antenna settings for every Satellite you can receive. You could do this ANYTIME so its done. I have it all in nice text DOC in my computer. #2 Download the new bin from the "home" forum for your receiver. Never pay for free info. Unzip the file and place it inside a folder on your computer named "new bin 12-03-09 or whatever the date is. #3 Go to Viewsatusa.com or wherever on the nett you can get one and get a FRESH UPDATED copy of the satfile. Place this file inside that folder you made today. #5 Use the Loader Program or USB drive to copy the channnel list FROM your receiver to the computer. Place that file indise the folder you made today. #6 Use the loader Program or USB drive to install the new bin, satfile, and Channel List from the folder you made today. #8 Connect your receiver back to TV, LNB and whatever else you normaly do. #9 Using you notes make sure all settings are the same as before in each satallite you can receive in antenna settings. #10 Turn it to a sat and if need be let it autoroll. Sometimes this step takes 3 min sometimes 10. If you interrupt it by changing channels it will take longer so just let it roll. #11 Watch tv. Be thankfull it works. #12 After using the receiver for a while go to the "home" forum for you receiver and report any Bug's or thank the coders for their hard work. Yes their are a few extra steps here than what some people will say do they do but when these steps are done they save ALOT of time and energy fixing trouble after a data loss. I have 17 sat's scanned with 2700 channels it would take me about 5 hours to get everything back the way I like it. I am sure others will jump here and say stuff like "I never do all that and I never have troube" That is fine I am just saying if you do this you will not have trouble due to data loss or settings being wrong. It takes me about 5 min to do this each time so its not a big deal. Upload Loader2 User Guide "Loader2" can download the firmware from PC to STB. 1. Install "Loader2" to your PC. 2. PLUG OUT YOUR STB FROM OUTLET. 3. Connect "NULL MODEM CABLE" between PC and STB. 4. Run "Loader2" on PC. 5. Run the "Tool->Configuration" menu and select serial port what you use. 6. Press "Open File" button and select the file what you want to download. 7. And then press "PC->STB" button. WHEN ZMODEM WINDOW IS APPEARING, PLUG IN YOUR STB. 8. Then selected file will download from PC to STB. 9. When download is complete, you can see below message. When you see this dialog on PC, STB will start to write flash memory. Please wait until STB automatically reboot. By THE FTA TESTER Gold Member Username: Ke5aqn |
Gold Member Username: NydasPost Number: 7714 Registered: Jun-06 | Get a USB drive and use your manual. Become a member at a reputable site with files - such as [link removed] [link removed] and READ...R E A D....R E A D. |
Gold Member Username: Saqeeb9000Post Number: 1842 Registered: Oct-07 | This is the loader 2 https://www.ecoustics.com/electronics/forum/home-video/266022.html |
Gold Member Username: Dude123Post Number: 1970 Registered: Jul-06 | First of all, calm down and write clearly. 2nd of all, if you dont have any experience with FTA then get some professional help if you dont want to kill you box. And if you want to do it by yourself then you must read and gather as much information as you can which are posted everywhere on the internet. For How to guides go to ftabins.net Only thing I can tell you right now is that you dont need to use any of the cable, since its an ultra and you can transfer bins using a usb stick..so no wiring hassle get all your files in the usb stick and tranfer it from there. |
Gold Member Username: Saqeeb9000Post Number: 1843 Registered: Oct-07 | and for new bins or files .. go to http://www.des*ifta.co.nr/ (remove*) |
Gold Member Username: Dude123Post Number: 1971 Registered: Jul-06 | Lol I guess it took me a while to type... |
Gold Member Username: Saqeeb9000Post Number: 1844 Registered: Oct-07 | B. Loading your BIN using USB Jump Drive Now its time to download your BIN Insert the Memory Stick in your PC and transfer the bin in. Then insert in your STB and in the Main Menu select System information and press OK Select Receiver Upgrade and press OK Go down to the bottom of the window, select USB and press OK A new window opens with some Korean files, years, etc. In the bottom of the window, it is your bin selects and presses OK VERY IMPORTANT. DO NOT TURN THE POWER OFF Press Menu key Select Installation and press OK Select Antenna Setup and press OK Select your Sat. Here if you have a DISEqC switch enter the port #, Motor or Legacy SW No LNB Type need to select (from new, you have only two selection Standard and Universal). STB will select your LNB Automatic Press Exit and select Yes for saving the settings Your back to Antenna Setup screen Here you have Three choices: 1. Channel Scan 2. Auto Scan 3. Blind Scan Select Auto Scan Press OK You are in the Auto Scan window and you see the Bird(Sat.) you selected and on the top of your screen are three options: 1. Search option 2. Network search 3. Scan Start You don't change nothing, go down and select Scan Start and press OK You do this for all the Birds (Sat.) you have Wait for Autoroll and watch TV |
Gold Member Username: Saqeeb9000Post Number: 1845 Registered: Oct-07 | Viewsat Setup Video Tutorial.zip |
